Thread: Redemption: The comp-ish style 5thD build
Old 11-06-2015, 03:50 PM   #61
onebullet's Avatar
Default Re: Redemption: The comp-ish style 5thD build
Originally Posted by Curcal View Post
The key is to actually finish this one....... :thumbs:
well, i know thats what everybody is thinking.
guess we will see what happens
onebullet is offline   Reply With Quote
Old 11-06-2015, 08:43 PM   #62
snapon boy's Avatar
We got your back!
snapon boy is offline   Reply With Quote
Old 11-09-2015, 07:58 PM   #63
onebullet's Avatar
got my chassis and slipper eliminator today and figured out i lost one of the long screws for my dlux truss. Going to see if i can find a screw at the local hardware store, nothing i have is long enough.
ill start with pictures when i can actually put stuff together.
if anybody has transmission spacers they are willing to part with for cheap i would be very grateful
Old 11-10-2015, 03:11 PM   #64
This screw long enough?
I have all kinds of spacers, just need some lengths on the spacers you need?
Address they the 3 that go between the tranny case and the motor plate?
I haven't found the output shaft spacer, yet...
winnerone23 is offline   Reply With Quote
Old 11-10-2015, 03:47 PM   #65
onebullet's Avatar
the screws from dlux are about 1.25 inches long. I would like to go a bit longer. I got some screws from the hardware store that work but they are phillips head sadly.
These are the spacers i am looking for. I have the smaller ones but they are plastic, would like metal. I dont have the bigger one at all
Old 11-10-2015, 04:16 PM   #66
That one in the pic is a little longer then that.. Nothing wrong with Phillips head..
Umm, plastic is lighter! I took metal ones off for the plastic ones.. But they have been used for spacers else where, over time..
I'll lyk if I find the output shaft spacer.. If I do, you can have it.
Old 11-10-2015, 10:20 PM   #67
snapon boy's Avatar
I've got the 3 spacers let me dig for the large one. Ok the ones I've got are plastic. They are yours if you need them and the price is free.
Old 11-10-2015, 10:50 PM   #68
onebullet's Avatar
i have the three plastic spacers, was just hoping to get metal ones. What i really need is the larger one, i can buy one but its 10 dollars for a tiny piece of tin......
Old 11-11-2015, 12:16 AM   #69
snapon boy's Avatar
I may have the metal ones I'll look tomorrow
Old 11-18-2015, 07:37 AM   #70
snapon boy's Avatar
How is your build going? I've got a lot of the parts for mine just waiting for the chassis to show up.
Old 11-18-2015, 12:01 PM   #71
onebullet's Avatar
Its going along, im about at the point i was last time. Just havent been posting because its nothing special.
I got a vp stage 1 kit for it and a strc diff cover for the front. Thats about it.
Old 11-18-2015, 12:30 PM   #72
snapon boy's Avatar
That sounds good! If I would stop adding to my order I think my chassis would be here. Troy has been a huge help!
Old 11-18-2015, 03:26 PM   #73
onebullet's Avatar
yeah, i dont think its very often that anybody can say troy was no help at all.
Old 11-18-2015, 05:54 PM   #74
snapon boy's Avatar
Did you get the blue stage one set?
Old 11-24-2015, 05:26 AM   #75
onebullet's Avatar
started painting the new body early this morning.... got this crappy picture. Lots to do yet.
Old 11-24-2015, 08:18 AM   #76
onebullet's Avatar
just finished the paint and really not happy with it..... time to stare at it for a bit and try to think of something to make it not so bad
ugh
Old 11-24-2015, 10:33 AM   #77
Looks good to me,
tapped-out is offline   Reply With Quote
Old 11-24-2015, 01:29 PM   #78
Originally Posted by tapped-out View Post
Looks good to me,
Yep, what this guy said! ;)
Old 11-24-2015, 11:48 PM   #79
onebullet's Avatar
the gun metal and black does look good together. Sadly that wasnt the paint job. Had man many goofs with this but i think the biggest problem for me was the color choice. The plan was to outline all the blue in black but i had changed my mind with the sides, should have done a sprayout first. I put on some decals to hide somethings and try to make myself feel better about. I still hate it. Not a straight or clean line to be found on the thing..... bahser body status i guess
very hard to see, but it says sucker punch across the back.
Old 11-24-2015, 11:56 PM   #80
snapon boy's Avatar
Ok Dan, it looks good to me.
Redemption: The comp-ish style 5thD build - Similar Threads
Campbell "ish" style w/ swaybar gadge 2.2 Scale Rigs 1 06-06-2013 12:25 PM
My Micro crawler build - Crawlerx chassis - comp style Tuna Losi Micro-Rock Crawler 54 01-29-2012 11:07 AM
TTC-ish Scale-ish Budget-ish Wroncho-ish Build Meatwad Axial SCX-10 77 01-19-2012 03:00 PM
