12-04-2016, 03:42 PM | #121 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
| Re: JENS' SuDuOne FL 2.2 Shafty
Very nice job! Looks very clean. |
12-06-2016, 11:35 PM | #122 |
Quarry Creeper Join Date: Apr 2012 Location: france
Good job Jens ;)
12-08-2016, 02:51 AM | #123 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
In order to get the front and rear wheels to rotate in the same direction with the new rear axle,-I have to flip the ring and pinion in the front axle. Then I have to reverse the motor aswell.... How do I check if the Puller 400 has got any timing,-it was ordered as a CCW rotating version.....if the timing is zero,there should not be any problems with just reversing the polarity on the motor.... ? : |
12-08-2016, 05:31 AM | #124 |
You're right about the timing. If it's 0* direction makes no difference.
12-08-2016, 11:46 AM | #125 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Looks great Jens! I think a 43/13 UD front gear would be perfect with the Scx II rear axle. It would be slightly less overdrive than our current OD/UD setups, which would be nice. |
12-31-2016, 07:56 AM | #126 |
| Re: JENS' SuDuOne FL 2.2 Shafty |
01-01-2017, 05:29 AM | #127 |
02-17-2017, 04:17 AM | #128 |
Installed the Xtra Speed Steel Heavy Duty Helical Spiral Gear & Pinion Gear Set which is 28/8 ratio yesterday....... The mesh and quality of these gears seems not that great..... And I've seen in the SCX10 II threads that they are not durable at all.... Have to give them a try |
02-17-2017, 09:23 AM | #129 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
Good Luck bud, hopefully they hold up for you.
02-17-2017, 03:09 PM | #130 |
Any link for those gears Jens?
02-18-2017, 01:38 AM | #131 |
03-05-2017, 05:33 AM | #132 |
03-07-2017, 01:26 AM | #133 | |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: JENS' SuDuOne FL 2.2 Shafty Quote:
03-19-2017, 12:38 PM | #134 |
04-24-2017, 12:57 PM | #135 |
Had our season opener comp this saturday,-quite windy and cold,-but very good to be back in the game The rig drove very nice after the winters rear axle swap After some earlier testing with the rear sway bar,-I decided to try it in the comp,-and it worked really well The rig is now stable and predictable And I like the little bit higher overdrive the 38/13 front and 30/8 rear gives vs. the common 36/14 and 43/13,-it climbs and turns great now ! I managed to take quite a comfortable win,-both rig and driver stayed focused during the whole day,-at least in shafty class,-mod class is another story completely : |
04-30-2017, 07:58 AM | #136 |
04-30-2017, 04:34 PM | #137 |
I like the black new look! When are changing the wheels and make all black? That would be awesome! |
05-01-2017, 12:02 AM | #138 |
05-05-2017, 08:45 AM | #139 |
Pebble Pounder Join Date: Nov 2016 Location: Southern California
Lookin good man!! Sent from my iPhone using Tapatalk |
05-14-2017, 02:05 AM | #140 |
Second comp in our series yesterday,-the rig is performing so great now,-feel like everything is just up to my driving Due to raining,-we only run three courses,the rocks got so slippery,-we had to think about driver safety,and cancelled the last three courses I managed first place again with only 11 points ahead,-not that happy with the score on course number 2,-but it was a bit tricky . |
JENS' SuDuOne FL 2.2 Shafty - Similar Threads | ||||
DravTech presents the SuduOne FL - 2.2 Sporty/Shafty chassis | Dravpnir | Chassis and Suspension | 29 | 09-24-2019 07:19 PM |
jens jeep | gooba | Axial AX-10 Scorpion | 7 | 04-27-2009 03:42 PM |
