Thread: JENS' SuDuOne FL 2.2 Shafty
Old 12-07-2017, 03:44 AM   #161
Default Re: JENS' SuDuOne FL 2.2 Shafty
If you're using the stock axle housing that would work. I've used the upper mount from bad_rax on stock and dana style ssd housings. That housing is nice because the bottom is smooth and round, no screws. It will also be the next big thing in custom axles with many companies making axle tubes for ssd centers. Some small modification was needed to use bad_rax mount on ssd but nothing major. Wide revo aluminum balls spread the links out nicely.
WHITE-TRASH is offline   Reply With Quote
Old 12-12-2017, 08:26 AM   #162
Originally Posted by JENS View Post
Well....,-maybe this will work.....
is this the axle from a scx10.2?
thanks
intheworks is offline   Reply With Quote
Old 12-12-2017, 10:31 AM   #163
thanks
Yes,-it's from the SCX10.2
JENS is offline   Reply With Quote
Old 12-16-2017, 01:37 PM   #164
Hi Jens ... did u cut your Voodoos or are they stock ?
Best regards from Austria
Manuel
msc project is offline   Reply With Quote
Old 12-16-2017, 01:38 PM   #165
im just wondering if i really have to cut mine .... dont really wanna do that
Old 12-17-2017, 04:57 AM   #166
Manuel
Hi,-the Voodos' are cut,-the stock width is too wide for my liking and steering clearance is also better when narrowed
Old 12-24-2017, 07:12 PM   #167
Thank you
Old 03-04-2018, 03:40 AM   #168
New batteries for 2018
Old 03-04-2018, 03:42 AM   #169
And a new motor,-Puller 400 Team 13t XX
Old 03-06-2018, 06:07 AM   #170
Nice upgrades!
I also bought some of those battery's after some zippy died on me on course in Eurocrawl.
Also I saw so many people run them and giving them good reviews, so why not try?!
xkill is offline   Reply With Quote
JENS' SuDuOne FL 2.2 Shafty - Similar Threads
DravTech presents the SuduOne FL - 2.2 Sporty/Shafty chassis Dravpnir Chassis and Suspension 29 09-24-2019 07:19 PM
jens jeep gooba Axial AX-10 Scorpion 7 04-27-2009 03:42 PM
