02-24-2016, 08:50 PM | #21 | |
| Re: Krazed Builds un-Stuck line into 2.2S Quote:
Wraith lockouts with no tubes needed? Just need axles made for them? Which Losi ones? From the lower links on the crawlers? Didnt even think about those because of the 1/8 rod. | |
02-24-2016, 10:50 PM | #22 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
| Re: Krazed Builds un-Stuck line into 2.2S |
02-24-2016, 10:50 PM | #23 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Yep, the wraith lockouts are slightly longer than those of the AX10 I ran them hard for a good 18 months with out failure. Including heavy rolls and jumping, There is a slightly larger than normal gap between the lock out and the hex. Perhaps 3.5mm give or take. but this has not adversly effected the 5mm Ti axles i was running. I am not specifically sure of where the Losi rod ends came from but would assume a crawler cause that is all I own and have owned. They look to be a 3mm or 1/8" hole but have similar diametre to that of a revo rod end. I have them on both my 2.2S and 2.2P tierod tapped to 3/16" also on the 2.2S rear lowers. Last edited by Highlucks; 02-25-2016 at 08:08 PM. |
02-25-2016, 05:18 AM | #24 | |
| Re: Krazed Builds un-Stuck line into 2.2S Something tells me that would be like dropping the anchor through the boat before even leaving the dock. Quote:
Hmmm def gonna look into that route with the axles, Thanks! And go digging through my Losi stuff. Thanks again. | |
02-25-2016, 08:01 PM | #25 |
No Worries man, Here is how the rear looks with the Wraith lock outs and special axles. I know Creeperbob makes some but I am also sure you could make your own. |
02-28-2016, 08:50 AM | #26 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
RC4WD made some M3 or 1/8" bent rod end too. I have been using it for my front upper link and it hold up nicely. The new version has less slope in it. I use one piece Ti 5mm rear axle made by egressor with wraith lockout the diamension is shown in the pic. By the using larger hub and/or bigger offset wheel is easy to match front and back track width without the unnecessary rear tube. |
02-28-2016, 10:38 AM | #27 |
02-28-2016, 04:52 PM | #28 |
| Re: Krazed Builds un-Stuck line into 2.2S Quote: Hows the plastic feel on the new ones? My experience in the past was a package of all broken ones. The plastic was hard which made it brittle to impacts. I actually found the Axial XR and Wraith angled ones may work better. Theyre thiccker around the thread area and shorter. Let me drop my drive angle and maybe last longer on corner hits during tumbles. Got a few more bits coming in this week to cosmetically dress the skid and hopefully drill the lower link pin holes in line on both sides. |
02-28-2016, 06:25 PM | #29 | |
M3 Short Bent Plastic Rod End (20x) | |
02-28-2016, 06:26 PM | #30 | |
Appreciate it - anythings worth a try | |
03-03-2016, 12:17 PM | #31 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
I've been running the new RC4WD angled rod ends for over a year now and haven't broke one yet. They also have some that are just like the Revo's. |
03-03-2016, 04:30 PM | #32 |
Rock Crawler Join Date: Jul 2013 Location: Manchester
Those aren't losi axles dude
03-03-2016, 06:36 PM | #33 |
03-04-2016, 08:01 PM | #34 |
03-10-2016, 10:17 AM | #35 |
03-21-2016, 08:56 PM | #36 |
So inventory is going out the door daily right now but I still was able to squeeze some me time in while the machine runs. So far the truck is working well through the practice Ive been able to get. Two things I noticed and am need to change is my foams and Rovers. Im pushing to leave the rovers on for NENC and RI since the traction is so knarly at these two places the lugs just work. But foams are def too soft. This truck has so much forward weight transfer that I roll the tires over no matter what I do to my driving. So I changed my lower links to be one hole lower then the rear and it really seemed to help free the nose up. Rolling over almost gone. I also changed my oils from 40frt/47.5rear to 35frt/40rear ...... this seemed to help the lightness react quicker for me. Ive always been the one to run lite rig lite oils ... I believe it helps the weight transfer quicker and give a better balanced feel when driving. but on the quest to lose some weight I started with the front. Easiest was to take wheel weight out, No I dont want to do that. Instead I got some aluminum tubes from RCBros and changed my locker out from the Vp one to the GripFab. Heres my starting axle And GripFab locker To the new axle A cool 30grams gone there and I left my 64grams out at each wheel. Next was that high boat anchor trans I have for now. Good Lord! Lets look inside ..... First to go was the solid Robinson For the Aluminum Robinson And HH outdrives And after a little drilling the holes out For a total of? Next was the idler shaft For a 7075 aluminun gun drilled one Wait! Is this thing working? Lets check ......... Phew scales not broke yet ...... but I moved on to the steel idler gear. Yup Im the crazy guy willing to run plastic Didnt do much to the top shaft though for now. Gave it a drill down the center but only saved about 2 grams there. Future plan is Aluminum like Krawlfreak did couple years ago. Back together I saved some good weight with just a few changes. A cool 35grams down ..... with future plans of a Carbon Fiber plate from BWD (he makes them and its about supporting other vendors), a lighter motor (got my eye candy looking at some), front drive shaft and eventually a new transmission. for now though its time to get some practice and see what we gained. Its so fun playing with this truck and bringing the grass roots back into driving. Oh and worked some tooling tonight for our Losi skid ....... got some cosmetic changes to make and tools to order but its getting there. Thanks for looking |
03-21-2016, 10:11 PM | #37 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Your skids look absolutely amazing. That was the biggest and nastiest cost factor to our chassis. Wish I could do them in house. Nicely done!
03-22-2016, 05:23 AM | #38 | |
Thank you. I hear ya, my table is such a mess doing them but the rewards worth it. They def take the longest to complete and luckily I work cheap lol. | |
03-22-2016, 11:45 AM | #39 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
03-23-2016, 07:32 PM | #40 |
89% happy with tooling, back to the CAD for the other 11% fine tuning. Sent from my 0PJA2 using Tapatalk Last edited by Robbob; 03-23-2016 at 08:11 PM. |
Krazed Builds un-Stuck line into 2.2S - Similar Threads | ||||
Krazed Builds Vacation 9/12-9/19 | Robbob | Vendors Market | 3 | 09-26-2016 11:55 AM |
Krazed Builds - AX Axle Krazed Plates | Robbob | Axles, Trannys, T-case | 8 | 10-28-2015 07:13 PM |
