01-26-2017, 06:50 AM | #101 | |
| Re: Krazed Builds un-Stuck line into 2.2S Quote:
He posted on Fbook he was selling it all off but running business as usual until someone comes up with an offer. | |
01-26-2017, 07:25 AM | #102 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
Shit thats right. Nevermind. My bad. I misread and havent had coffee yet at that time |
01-26-2017, 09:09 AM | #103 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
| Re: Krazed Builds un-Stuck line into 2.2S The matte carbon fiber from Dravtech is definitely some of the nicer carbon that I've seen. Honestly, seems like the EU has better carbon fiber than we do in the states. Everything I've bought from you and RCBro's has been stellar, but that matte finish on Dravtech's just gets me.
01-26-2017, 10:12 AM | #104 |
Quarry Creeper Join Date: Jan 2014 Location: Western Wa. Mose Capital of the World
| Re: Krazed Builds un-Stuck line into 2.2S |
01-26-2017, 11:14 AM | #105 | |
01-26-2017, 11:43 AM | #106 |
| Re: Krazed Builds un-Stuck line into 2.2S Honestly, I just like the way it looks, but I also like matte over gloss with most things in life.
01-26-2017, 03:07 PM | #107 |
Pebble Pounder Join Date: Sep 2013 Location: matane
I follow your build thread and it is nice to see how it have goes ,but my biggest guess is where you are on the tranny you would build,i am looking to build my own with xr10 gear in a few days i will try to make me something but would like to have a little bit of your know on??
04-07-2017, 08:32 PM | #108 |
04-07-2017, 08:53 PM | #109 |
That pink is pretty sexxy. Looks a shade or two darker than the other pink I've seen printed, or is that the camera playing tricks? You need more knuckle weight. Probably should add some on the rear axle too. |
04-07-2017, 08:57 PM | #110 |
| Re: Krazed Builds un-Stuck line into 2.2S Same pink, just the filters I used in Lightroom. If I cant get the real to settle down I may just end up with an ounce or two back there. Damn things too light for the tires to bite good |
04-07-2017, 09:03 PM | #111 |
Since swapping in an scx rear axle mine is too light out back. Need to remail my weight holder to fit scx lockouts. Damned savox will throw the rear around if the front is remotely wedged. What's the final weight? HR aluminum gears in the trans? If your trans is over 64 grams you need to talk to that crawler guy in Utah. I have it on good authority it will fit your chassis. |
04-07-2017, 09:06 PM | #112 | |
3.6 on the scale rtr .... and Ive been eyeballing a hamburger | |
04-07-2017, 09:08 PM | #113 |
ooops 4.02 after the tire and wheel swap
04-07-2017, 09:14 PM | #114 |
Fawk... last I weighed mine they were 5.2 and 5.3lbs. El pinko should be under 5 with the new treads and a few other bits. The hamBerger will fit, not sure the CheezBerger will though. I know for a fact the CheezBerger will fit, but it was prototyped in an unstuck V1. Get SAF low ratio gears while you're there, you won't regret it. Last edited by WHITE-TRASH; 04-07-2017 at 09:16 PM. |
04-08-2017, 07:44 AM | #115 |
04-08-2017, 08:36 AM | #116 |
| Re: Krazed Builds un-Stuck line into 2.2S The skid isn't the issue. It's the crossmember directly behind the skid that can interfere with the motor. It's already real tight with a standard 540 but the HamBerger fits. The CheezBerger has a 5mm spacer to move the motor back, it is also mounted a bit higher so it might juuuust clear that crossmember.
04-22-2017, 05:56 PM | #117 |
Well I cant say I could be any happier with the un-Stuck .... season opener in the rain and a win on its first real comp for the new design. |
04-23-2017, 02:06 AM | #118 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
Congrats on the wins!
04-23-2017, 07:43 AM | #119 |
The chassis(s) work very well. The V2 adjustable rear shock arms are sweet, I just moved mine yesterday as a matter of fact. The geometry is good too. |
08-08-2017, 12:52 PM | #120 |
Quarry Creeper Join Date: Nov 2013 Location: Huntsville
Robbob, images are broken!
Krazed Builds un-Stuck line into 2.2S - Similar Threads | ||||
Krazed Builds Vacation 9/12-9/19 | Robbob | Vendors Market | 3 | 09-26-2016 11:55 AM |
Krazed Builds - AX Axle Krazed Plates | Robbob | Axles, Trannys, T-case | 8 | 10-28-2015 07:13 PM |
