01-26-2016, 04:10 PM | #1 |
Newbie Join Date: Jan 2016 Location: Canada B.C.
| Change spur pitch to 32 and slipper clutch ?
Hello guys I have the older ax 10 scorpion. model # ax90004 i00 ARTR . It's the one that has no slipper clutch. 1st question. is it good to have one ? . And what 32 pitch spur gears would work (Metal or Plastic) ? I'm using a Novak Havoc ESC with 55t axial brushed motor and what would be a good gearing for 32 pitch
01-26-2016, 05:09 PM | #2 |
| Re: Change spur pitch to 32 and slipper clutch ?
I would just keep it with the slipper eliminator. The DuraTrax Spur Gear 32P 56T Nitro Evader BX will work TowerHobbies.com | Duratrax Spur Gear 32P 56T Nitro Evader BX I would run a use a 32p 10t or 11t pinion with it. |
01-26-2016, 05:44 PM | #3 |
Cool thanks man
01-26-2016, 06:42 PM | #4 |
Hey do you happen to have a part # for a pinion buy any chance . I have been looking for one that would fit that spur and size of my motor ? I'm kind lost
01-26-2016, 08:31 PM | #5 |
| Re: Change spur pitch to 32 and slipper clutch ? Robinson Racing Products - Products and Pricing - 1/8 inch bore motor pinion gears These are 1/8" bore pinions, 32p is in there too. Your axial motor has an 1/8" shaft. |
01-26-2016, 09:09 PM | #6 |
I just found that the32p 54t traxxas spur # 3454 would work , so if got between 9t and 12t pinion it should work ?
01-26-2016, 09:25 PM | #7 |
Yup, geared to your preference.
01-26-2016, 09:28 PM | #8 |
Thanks guys much appreciated
Change spur pitch to 32 and slipper clutch ? - Similar Threads | ||||
How to assemble the 32 pitch slipper clutch? | micro racer | Axial SCX-10 | 8 | 06-27-2016 03:12 PM |
What to use to change to 32 pitch or stronger spur | Famous112 | Axial Wraith | 11 | 09-09-2013 11:40 PM |
Slipper clutch/ spur gear | meanbgreen | Newbie General | 6 | 09-02-2011 08:20 AM |
