05-13-2016, 09:26 AM | #41 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Sic's sporty...
Thanks Erik!!! I seen those unique knuckles b4 in your thread. I tried to get weight out far as possible with your brass knuckles im using now. Should be ok...what u think? I was gonna holla & see bout getting your delrin hubs since im running ofna outers & do away with hub spacers? With some other stuff too! I may just run weight setup like this since my width up front is 10 3/4 now....& Got the weight out there more too. Btw I got a box yesterday too from ya...different thread tho Last edited by sic1to; 05-13-2016 at 09:29 AM. Reason: Do you want me to tell Troy he cant have em or me? Lmfao |
05-13-2016, 09:58 AM | #42 |
| Re: Sic's sporty...
I guess it depends on what width you want. I would get there and then figure out how to adjust the weights. If youre running two 1/4" spacers and the stainless hub, you should be able to move to a 475 delrin hub and eliminate all that extra stuff. We can both tell Troy he cant have anything. Its more fun that way. |
05-13-2016, 10:12 AM | #43 |
| Re: Sic's sporty...
See how your product works...I put it on wrong or another way & it still works I will run it & see how it feels today. I told him you wasn't trying to hear it lol
05-13-2016, 02:40 PM | #44 |
| Re: Sic's sporty...
You can also put the delrin behind the carbon like I said above. If you need to space them out wider to fit in the wheel, then you can add spacers between the carbon and the knuckle. It will space the whole thing out. Should be much easier to get correct that way.
05-13-2016, 02:56 PM | #45 |
| Re: Sic's sporty...
That makes sense duh I will get it all buttoned up & test it more tommorrow at regular spot!
05-15-2016, 03:02 PM | #46 |
| Re: Sic's sporty...
Its the weekend so mandatory run time happened... A lil video to see https://youtu.be/4oFpmQ0XK-I This whole loaded dice setup is amazing... Thanx DLUX!!! Last edited by sic1to; 05-15-2016 at 03:04 PM. |
05-16-2016, 09:23 PM | #47 |
| Re: Sic's sporty... |
05-18-2016, 06:58 AM | #48 |
| Re: Sic's sporty...
Found some SDI prop shafts I ordered for this build but forgot about em I was using axial hd in rear & traxxas or og axial up front.... Now the weight vs strength comparison between em fully assembled A whoppin 1.7 grams more....wait incorrect I Forgot the pics is new uncut sdi shafts! Now puts them at 50.1 grams which is 3.4 grams less with new shafts Used a bearing to shim pinion f&r Got plenty of room for larger spur without a extended trans output. (Im runnin 56t spur) The shafts do require a lil cutting to fit application. I will run it to see how the set screws holds up? I modded some pin type set screws so at diff & trans there is material passing through the holes not just holding like grub screws Looks like rain is gone so after work today its on |
05-18-2016, 04:30 PM | #49 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
| Re: Sic's sporty...
I used the pin type set screws and drilled it so the pin goes all the way through and have been running SDI shafts since last season and have beat on them pretty good with no issues! I really like the SDI's. Your sporty came out sweet! |
05-18-2016, 05:14 PM | #50 | |
| Re: Sic's sporty... Quote:
Ty for comments! | |
05-18-2016, 05:23 PM | #51 |
05-18-2016, 05:23 PM | #52 |
| Re: Sic's sporty...
I've been running one in the rear, for a little while now.. the worst that has happened, so far.. 1. Was the slide pin cover, unscrewed and I lost the pin.. so I finished the comp with a body pin, in it's place.. 2. Was shearing the set screw off. Inside the output.. which I have seen a few times. I now run a solid screw, in place of the set screw.. Other then them 2 small things. It's been over a year.. But I still won't take the MIP off the front.. lol.. |
05-18-2016, 05:30 PM | #53 |
05-18-2016, 05:37 PM | #54 |
| Re: Sic's sporty...
Sand, dremel, file, the hole open a touch.. Or sand the threads off the screw. So it fits. |
05-18-2016, 06:05 PM | #55 |
06-02-2016, 12:21 PM | #56 |
| Re: Sic's sporty...
Gettin close to ECC so a lil update... Changed HH 500 to a 7950! No issues with HH servo just put it on another(4ws)rig to match the rear. I used cf pieces to hold servo down & hopefully no broke ears! Got some blue G10 arms as seen above! Started the weight setup...I had Dlux brass knuckles with slugs & now Im using 7075 centers(with slugs drilled) blue G10 arms & loaded dice weights! Which got changed so that the weights are all the way out to wheel faces! You can see the weights are inside on last pics & now they are on the outside with clearance & proper wheelbase. Oh yeah got another flavor of wheels too! All for now but tommorrow a special surprise will arrive... Last edited by sic1to; 06-02-2016 at 12:23 PM. |
06-03-2016, 08:07 PM | #57 |
| Re: Sic's sporty...
With 1 week away from ECC the wait for HH motors is done. I pulled the trigger on a Team Brood stubby 5 slotHHK 16t with the works!!! Ok so yeah it was exspensive to say the least but so far its a motor it will be tested tommorrow to see where it stands. The rig well it is now back down below 3lb14oz with motor swap. The HH TM pro 35t is still kickin (3 yrs now) it just lacks in what im used to on pro truck (13t pullers)!!! I can say it matches my paint scheme nicely |
07-17-2016, 05:30 PM | #58 |
| Re: Sic's sporty...
Alot has been goin on since last post on this awesome EVO Ok SO ECC,ETRC,SCRCC & then NENC this year have been the best times since i got into crawling & I have learned alot! No pics really but i did burn up a 7950 or maybe 2 & 1 stripped servo horn. I am now running the HH500 with no issues at all. ECC-13th ETRC-1ST SCRCC-6th(I think?) NENC-8th Im really pleased with where i placed considering the drivers at these events & the couple lil mech failures After attending these events its easy to say its more than just competing. The Drivers,event holders,environment & meeting new people is what its about! I think one or two more local events then get ready again. A big shout out to all the vendors & people on RCC that make awesome parts & helped me get these rigs up & running! Last edited by sic1to; 07-17-2016 at 05:35 PM. |
08-02-2016, 06:45 AM | #59 |
| Re: Sic's sporty...
We had another ETRC comp this past weekend & the evo did work! The truck is really feeling planted & predictable. With some of my best finishes the evo landed me a 1st place! Only changes from nenc were a lil more weight up front & went to 60w rear-50w front shock oil from 30-40. It really helped with sidehill & vertical climbs goin thicker in oil as well as slowing travel down a bit too oh yeah im back to the HH500 after burnin up a 7950 at last event..everything else stays the same!!! The next stop is ETRC finale |
09-25-2016, 04:00 PM | #60 |
| Re: Sic's sporty...
UPDATE!!! Im still running the hv500 with no issues there but the front diff was making a gear skippin sound when I had it bound up this weekend. ETRC #8 was a hot one but evo didnt care taking another 1st place finish I havnt touched the truck since .......... |
Sic's sporty... - Similar Threads | ||||
sic's g6 | sic1to | Axial SCX-10 | 33 | 12-11-2016 07:53 PM |
