04-05-2017, 01:58 PM | #21 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Little Betty my AX10
Little Betty in Tour Porec Croatia on the Beach Gesendet von meinem Nexus 5 mit Tapatalk |
04-07-2017, 07:31 AM | #22 |
driving on the rocks at the beach i mentioned too much flex. in extrem like front axle is upside down, rear axle is normal. before with the stiffer springs blue axial i hadnearly no flex. to get it like i want i think it's a matter of spring setup. or is there another parameter i have to mention. i managed the setup of my little monster (yeti) but crawling which is the main propose of little betty i have no clue. still a complet noob. another issue i have the hyrax 2.2“ are very sticky on the rocks, which is fine on the surface. but the tire sidewall hangs on rocks. is this something i could change with differend foams? i still have the standard foam that came with the hyrax. would be the ci dw tall better? nother question i have 128mm shocks from the ax10 kit even with the softes springs i have the shocks full extended. i thing it would be better if they are let's say 40% compressed. which would be a good set up for a terain like shown in the pics above? thx for youre opinions. crawling is complet new to me. how do i get little betty to a good capable crawler? without changing it complete. i know xr mod other chassis..... but i want to keep it near to how it is yet... but also want to improve the performance Gesendet von meinem T1-A21L mit Tapatalk |
07-08-2017, 10:20 AM | #23 |
Some updates for little betty Installed the mechatronik steering and made an diy steering link, a little wobbeling like using an servo saver. So far i'm happy with it, but i think it's not the final solution. Installed hi-clearence links front and rear and chnged mounting pos (shocks now on the outside). Also installed a 4 link mount with diy upper links and changed rear springs to a dual spring set up. Rotated the skid, motor is now on the left side. Replaced the CC Sidewinder esc for an hw 1080, cause i decided to stay brushed on little betty. Little Froggy needs his esc back. Couldn't resist modified the skit to mount links inside. For the first test drives i use an lipo checker to check cutoff Also made some rock lights powered direct from the balance port of 3s lipos. Still have an weight ratio f/r 60%/40% or 55%/45% depending which accu i use, total weight 2,5kg incl. Accu. Urban crawling on the river. Little Betty did it really well, very happy how the setup came out. I don't know which change did it but no torque twist any more. Last edited by magic_yeti; 07-09-2017 at 10:52 AM. |
07-09-2017, 11:16 PM | #24 |
Rock Stacker Join Date: Jan 2017 Location: Athens, Greece
Little Betty is sweeeetttt! I have noticed from the pics that you are using spacers on the upper links..is it better that way??
07-10-2017, 04:37 AM | #25 | |
| Re: Little Betty my AX10 Quote:
Never thought about it, cause the former three link uses them so i left it as i installed the 4 link. Have to try it without sometime, to test if it will make a change. So far i'm happy how it performs, but i lack of comparison with others. | |
09-01-2017, 06:42 AM | #26 |
Wasn't really Happy with the Mechatronik steering cause it was a little slopy. So i hit the trigger in some Sale items All from xtraspeed cvd xh hard, alloy Front Hub Conversion and alloy Front Caster Block for scx10. Fit perfectly, except one cvd needed a little sanding to fit the axle bearing. Have to Fab new steering links before i can tell if it will be an improvement but looks promising. Gesendet von meinem Nexus 5 mit Tapatalk Last edited by magic_yeti; 09-01-2017 at 06:46 AM. |
Little Betty my AX10 - Similar Threads | ||||
Oldschool AX10 Betty body. A new look. | T I N Y | Paint and Body | 4 | 11-21-2012 05:49 PM |
My AX10 with pitbull chassis and hacked betty!! | DonovanP | Axial AX-10 Scorpion | 40 | 01-22-2009 08:48 AM |
AX10 betty = scale brush fire truck?? | bnoland | General Scale Talk | 21 | 10-08-2008 09:21 AM |
Finished my Betty Body (Ax10 Axial Scorpion) | Knoc | Paint and Body | 31 | 07-31-2008 04:54 PM |
