04-13-2017, 04:11 PM | #1 |
Newbie Join Date: Mar 2017 Location: US
| Hey I'm new to the rc crawling and trailing
Need as many pointers as possible. I have a axial .. just picked it up a month ago.. don't know what model.. buy have been upgrading it a little at a time.. anyone know what axial this is?
04-13-2017, 04:39 PM | #2 |
Rock Stacker Join Date: Jan 2017 Location: Australia
| Re: Hey I'm new to the rc crawling and trailing
Have a pic or something to go off? Sent from my A1601 using Tapatalk |
04-13-2017, 07:20 PM | #3 |
Parts I've changed.. am I going the right direction..lol Sent from my SM-G935V using Tapatalk Last edited by THX_138; 04-14-2017 at 08:23 PM. |
04-13-2017, 07:50 PM | #4 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
04-13-2017, 07:54 PM | #5 |
| Re: Hey I'm new to the rc crawling and trailing |
04-13-2017, 08:03 PM | #6 |
Believe it or not most 1/10 scale 'crawler" bodies fit. Personally I would run the parma exciter or losi grappler body if ya wanted cheap comp body that alot of guys use! Ya gotta start somewhere & ya at the right place for endless knowledge On crawlers & more. I would stay in this thread & read the sticky's a few times then should have a very good idea what direction is for you! |
04-13-2017, 08:04 PM | #7 |
Thanks for the info.. I have a few videos but don't know how to post them.. I've done some gear and motor changing as well. Sent from my SM-G935V using Tapatalk Last edited by THX_138; 04-14-2017 at 08:25 PM. Reason: Merge, posts a minute apart |
04-13-2017, 08:09 PM | #8 |
04-13-2017, 08:12 PM | #9 |
I'm running a 17t motor.. had a 55t .. Sent from my SM-G935V using Tapatalk |
04-13-2017, 08:14 PM | #10 |
17t is much more modern & better for most part depending on motor internals! Im not fimiliar with the one ya posted but if ya want the very best go holmes hobbies for all your electronics!!!
04-13-2017, 08:31 PM | #11 | |
https://youtu.be/s8VcvPBojNY https://youtu.be/17raVtbPm74 Sent from my SM-G935V using Tapatalk Last edited by THX_138; 04-14-2017 at 08:26 PM. Reason: Ditto | |
04-14-2017, 09:18 PM | #12 | |
MODERATOR Join Date: Oct 2010 Location: RC Land
| Re: Hey I'm new to the rc crawling and trailing Quote:
Then say you dumped a 55 turn motor for a 17 turn You will NOT do much crawling with a 17 turn unless you're looking to dig trenches and shoot rooster tails the entire way. A 17 turn mounted into any sort of crawler instantly turns it into a bashing rig to spin tires, go fast and annoy anyone out wanting to enjoy a day of crawling or trailing.... it's just too fast of a motor The numbers work backwards. As the number of turns go UP... the speed goes DOWN and torque increases As the number of turns go DOWN... the speed goes UP and torque needed for crawling goes out the window QUICK My own opinion... 27 turn is about the fastest you may want even for trail riding. 35-55 turn is a good window to stay in for crawling, especially if you're new to the hobby. Last edited by THX_138; 04-14-2017 at 09:21 PM. | |
04-15-2017, 04:47 AM | #13 |
Thanks for the info.. useing a 17 turn also breaks stuff.. I've switched back to a t55. Ok so what's the most common motor and gearing to run.. I bought the metal trans and transfer case upgraded my outer axle housings to metal... changed shocks .. shocks..lol. tried flipping them.. can't do it on my crawler hits everything lol Sent from my SM-G935V using Tapatalk Last edited by THX_138; 04-15-2017 at 09:22 AM. |
04-15-2017, 09:39 AM | #14 |
You'd have to give a ton of information to get any answers on common gearing. When you jump from playing with RC toys off the shelf in Wal-Mart in the backyard or driveway, versus entering the scale realm a LOT of variables apply before answers could be given. To ask even common gearing , beyond the above 27 turn to 55 turn answer being the common window, the answers to these things below would be helpful and needed. • what RC do you have • what axles are in it • what trans is in it • what size tires are on it • what is the terrain you're mostly wanting to be on • composition of terrain Etc... Etc... Etc... Once you go from "toy" to a hobby purpose, a lot of variables apply to generate answers. There are endless great threads out here on the forum with info on your questions. A little time utilizing the search function that I've already linked you to by PM will generate you a metric ton of info. Again, tons of great info, but here's just a random sampling on motor turn info that's out here to read and learn from. Usually, any person that's created a thread like that would gladly accept a PM from anyone and help with any more specific questions privately. Understanding motor turns |
04-15-2017, 03:24 PM | #15 | |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
Me personally I run a 16t in one trail rig and 3300 kv in the other 3. All crawl very well and when you need that extra wheel speed it's there, otherwise we just crawl along. | |
04-15-2017, 09:34 PM | #16 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
Michiganwabbit, nice rig so far. When choosing a motor it is very important to know all info like THX 138 said. Some of the guys I trail with run 16 Turn motors but they are 5 armature motors, a 17 turn is about like a 35 turn 3 armature. You can get away with the faster motor if you GEAR DOWN. Anytime you go to higher voltage or faster motor you gotta gear down. If you don't you will probbably burn something up, or at least overheat stuff. You have a good start with that rig, I would start taking it out and running it. As you find the weak points fix them. It is also good to do searches here and study the threads and ask questions. Listen to the guys at your LHS also. Ask people with simmilar rigs what they are running. Unless you are there competition they will prob help you out, heck even if the are racing against you most guys will help you out. Good luck. Keep crawlin'
04-16-2017, 02:36 PM | #17 | |
Sent from my SM-G935V using Tapatalk | |
04-16-2017, 08:40 PM | #18 |
Pebble Pounder Join Date: May 2014 Location: SF
First thing I would suggest is READ a lot, look at the tricks and tips sticky at the top of this section and the search button is your friend. A lot of the stuff you will ask is here somewhere. A lot of trail and error also. Welcome to the most addicting hobby I have ever been involved. |
04-26-2017, 06:56 PM | #19 |
An easy way to stop tire rubbing is to limit shocks with a small section of rubber tubing (fuel line...cheap$$$.) Remove shock rod end and put tubing on and put end back on. If looking for the most travel available just keep trying different lengts till you get it right. I like my shocks as soft as I can get them without bottoming out on the terain I am running on. To tune the shocks try some lighter / heavier oil also. I like to "balance" my front and rear also. With rig on level surface lift 1 rear wheel, the opposite fron wheel should bottom out aproximately the same time as the one you are lifting. If they don't try changing springs and/or spring preload. It realy is a good place to get started, but not always perfect. It may still need some tweaking. Good luck
Hey I'm new to the rc crawling and trailing - Similar Threads | ||||
New Crawling/Trailing Course | RcMudder | Formula Offroad | 5 | 05-18-2015 10:46 PM |
Need crawling/trailing buddies | shiftface | Oregon | 2 | 01-13-2015 12:34 PM |
New to Crawling/Trailing.... | Airbus9e | Newbie General | 0 | 05-02-2014 03:44 PM |
Anyone doing any trailing/crawling around North GA? | JDeezie82 | Georgia | 4 | 07-02-2010 09:06 AM |
