04-02-2018, 07:19 AM | #41 |
| Re: Dlux has gone off the deep end
More pictures as promised! Trans installed, links have been made and for those who were really concerned about the crooked cross brace, it now has screws holding it so its straight and you can sleep well. Last edited by Erik D_lux; 04-02-2018 at 07:25 AM. |
04-02-2018, 08:25 AM | #42 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Awesome ideas here for sure. My TRX-4 build uses a Hamberger and I wanted to side mount the trans but silly SORRCA rules and chassis stuff made that something I ran out of time for.
04-02-2018, 10:19 AM | #43 |
Nobody pays attention to detail these days eh? All these pics and nobody has caught that one big ginormous detail yet...
04-02-2018, 10:33 AM | #44 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
I just really surprises me that no one has noticed the most crazy insane part of this thing yet? Maybe because it’s such a drastic departure from the norm? Like hiding in plain sight? Idk?
04-02-2018, 10:56 AM | #45 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
So, is this the cheeseburger trans since the outputs are coming out different? What kind on difference does this give you?
04-02-2018, 11:16 AM | #46 |
It’s got BTA steering.
04-02-2018, 11:16 AM | #47 |
It is. It fights torque twist because they are spinning opposite directions.
04-02-2018, 11:34 AM | #48 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
What is the length of the chassis ? Is it a scale rig..... Last edited by JENS; 04-02-2018 at 11:39 AM. |
04-02-2018, 11:47 AM | #49 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Following this very interesting project...
04-02-2018, 11:54 AM | #50 | |||
| Re: Dlux has gone off the deep end Quote:
It gives overdrive to the front, so you can use the same gears front and rear. It also has counter rotating shafts so it helps eliminate torque twist. Not anymore. Try to keep up! LOL Pretty long relatively to sporties. About 10" | |||
04-02-2018, 12:03 PM | #51 | |
Rock Stacker Join Date: Jan 2017 Location: Bakersfield
Why didn’t you go high pinion on the rear axle? Sent from my iPhone using Tapatalk | |
04-02-2018, 12:13 PM | #52 |
| Re: Dlux has gone off the deep end |
04-02-2018, 12:44 PM | #53 |
| Re: Dlux has gone off the deep end The Cheeze trans needs one of the axles to turn opposite so I had to choose between the front and rear which would be low pinion. Ideally, I would have made it high pinion. Your questions will make more sense soon. |
04-02-2018, 12:53 PM | #54 |
04-02-2018, 12:59 PM | #55 |
Its actually so simple its stupid. I am just taking something that has been around forever, even on RC cars and applying it in a different way so its works better. Some will be like "how did I not think of that", some will be like "that is stupid and will not work". You have to know something about the way suspensions and links work. If you do, you will understand the logic and how this will work so well together. |
04-02-2018, 01:33 PM | #56 |
I is gonna run sway bars instead of shocks, with ride height determined by some sort of doohickey setting the torsion bar to a set level. Like the Nissan hardbody.
04-02-2018, 02:29 PM | #57 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Looks like you only have room for one upper link in the front and rear. That combined with the length of the chassis makes me think you're going with pan-hard bars front and rear for better packaging.
04-02-2018, 04:34 PM | #58 |
04-02-2018, 05:25 PM | #59 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
The chassis plates are cut different for upper link. One side is cut out for nothing while the other has holes. Hmm....
04-02-2018, 05:37 PM | #60 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
like how stiff you trying to go? damn all those braces lol. flex tuning im sure.
Dlux has gone off the deep end - Similar Threads | ||||
Took a drive off the deep end, C3 XJ 10.1-2 | Jeepy84 | Axial SCX10 II | 6 | 08-29-2017 07:13 PM |
C0bra's jump off the deep end! | c0bra | Multi Axle Rigs | 2 | 03-29-2017 02:58 PM |
DLUX Front End Guide and Wheel Fitment | 802coma | Axial Yeti | 46 | 04-10-2016 10:18 AM |
Give a way! UC fab sway bars and Dlux end links | Erik D_lux | Axial Yeti | 176 | 03-17-2015 03:58 PM |
Give a way! UC fab sway bars and Dlux end links | Erik D_lux | Axial Yeti XL | 37 | 03-13-2015 01:02 PM |
