05-19-2018, 11:00 AM | #1 |
Newbie Join Date: Aug 2013 Location: PRK
| Axial AX10 Scorpion trans from WK and Traxxas metal gear transmissions?
8-So I've got a metal gear WK and Traxxas transmission, plus HPI and Traxxas yokes. So if I grab a AX10 trans case, what do I have that I can use, and what do I have to buy? Thanks |
05-19-2018, 01:45 PM | #2 |
| Re: Axial AX10 Scorpion trans from WK and Traxxas metal gear transmissions?
If you buy an ax10 trans case counting what you already have you'll still need everything but the case since none of that other stuff is compatible.
05-19-2018, 07:30 PM | #3 |
I knew when I read that some parts were compatible with the WK it was too good to be true
Axial AX10 Scorpion trans from WK and Traxxas metal gear transmissions? - Similar Threads | ||||
ax10 metal trans gears................ | bob1961 | Axial AX-10 Scorpion | 7 | 05-06-2008 08:33 PM |
