Thread: Sportsman build question
Old 10-11-2019, 05:41 PM   #1
Default Sportsman build question
Hi i am actually looking to rebuild me a sporty so i am wanting to know some info on parts and active vendors .
So my first question is what would be your tranny choice ,,, scx10,dlux ham or cheese??,hulksta and other one if i miss something and with your tranny choice what would be your motor and pinion choice???
I am trying to collect all my parts and after trying to post a build thread.
Thanks
pyranahryder is offline   Reply With Quote
Old 10-12-2019, 02:14 PM   #2
Default Re: Sportsman build question
Tgs productions make the margouilliat shafty. It used rc4wd gears which is hard to get so he makes them for that gearbox.
Skickat från min iPhone med Tapatalk
Johan_Eriksson is offline   Reply With Quote
Old 10-14-2019, 05:10 AM   #3
I use the dlux hamberger with low ratio SAF gears in a lot of sportsman builds I do. I always recommend it for its light weight and versatile mounting.
WHITE-TRASH is offline   Reply With Quote
Old 11-22-2019, 09:18 PM   #4
5th D Owner/Driver
cboggs's Avatar
Classicutcustoms Bulldog trans has been solid in my sporty for many years with zero maintenance. It also uses berg gears, Im using RCBros lightweight aluminum gears and SDS 3rd. Its an enclosed trans and a bit more compact than the others. Dlux Hamburger is another choice but a bit tighter fit.
cboggs is offline   Reply With Quote
Sportsman build question - Similar Threads
Sportsman body question nitrooxide General Crawlers 7 01-25-2013 05:07 AM
my (sportsman) build 27cameron Axial AX-10 Scorpion 22 06-05-2012 07:22 PM
sportsman question BigSki WRCCA Rules 3 01-09-2012 05:06 AM
My first sportsman build adamargue HPI Wheely King 45 04-13-2011 07:21 AM
Sportsman or Mini that is the question... ittybitty South Carolina 15 11-12-2010 02:23 PM
