Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: My AX10 Building thread.
Old 07-30-2007, 05:11 AM   #1
Default My AX10 Building thread.
I have ordered these things to my AX10
ESC
Castle Creations Mamba Max Electronic Speed Control (ESC)
Motor
BM9 Brush less Motor - High power motor for your 2.2 crawler
Adapter
Motor mount/adapter for small brush less motors.
Servo
Blue Bird BMS-660MG+HS
Speed At 6.0V: 0.15 sec / 60° at no load
Torque At 6.0V: 14.6kg-cm , 195 oz
2*Sun power 7,2V NiMH 4000 mAh
And a Futaba 3PM
Canīt wait until the AX10 is out on the market
Any coments on my setup?
bjornsson is offline   Reply With Quote
Old 07-30-2007, 06:34 PM   #2
Not tring to jump in on your build Set up sounds good to me . But this will be my 2nd 2.2 rig. I'm going budget minded(cheap).
Axial ax10 RCP 248.00 shipped
Moped VR16 esc vendor 25.00 shipped
Hitec 645 servo RCP 38.00 shipped
TQ3 traxxas Ebay 25.00 shipped
55T lathe + 20.00
$356.00
Will add more later.
Servo/batt mount RCP??? (not avail yet)
Tires will try stock. if they
are bad as people say
I'll get Moabs tower hobbies 30.00
What do you guys think of this set up
tapped-out is offline   Reply With Quote
Old 07-31-2007, 11:59 AM   #3
should be sweet man
BrandonW is offline   Reply With Quote
Old 08-04-2007, 10:48 AM   #4
55T lathe + 20.00
$356.00
I like the losi rock claws better than the moabs
CHEEZBURGER is offline   Reply With Quote
Old 08-04-2007, 10:53 AM   #5
I like the axials better than moabs and mashers. I haven't tried the losi rock claws.
Shaun is offline   Reply With Quote
Old 08-04-2007, 11:48 AM   #6
What about all that mud riding I'm seeing on here. What is the best ESC/Motor combo for that. I already have a Novak SS and a LRP Sphere to put in one. I know neither one of those are water resistant. But on that same subject, is the Novak Crawler ESC WAAAAY better than the plain Novak SS for crawling and trail riding?
NitroStar is offline   Reply With Quote
Old 08-14-2007, 07:05 PM   #7
the novak crawler is ultimate, ultimate and expensive. for mud and water, MTroniks makes a waterproof esc that i see some guys using on here and on orcrc. if you are gonna be mud running then get a low turn motor with some fast gears (wheel speed is key). remember to clean out your motor.
grapegoat is offline   Reply With Quote
Old 08-15-2007, 02:17 PM   #8
Well Heres My Setup Any Suggestions
1.ax10 Scopion(of Course)
2.novak Rooster Crawler
3.integy 55t
4.tq3 Radio
5.hi Tec 645mg
6.venom 3000mah Battery
Dirt Trak Racer is offline   Reply With Quote
Old 08-15-2007, 02:19 PM   #9
dirk379's Avatar
3.integy 55t
4.tq3 Radio
5.hi Tec 645mg
Yeah dont buy the novak rooster crawler. Basically all it is is a xrs circuit bored with a heavier drag brake and new look. Thats what novak themselves said
dirk379 is online now   Reply With Quote
Old 08-15-2007, 03:19 PM   #10
Rockpiledriver's Avatar
Wrong. If you are going to bash a manufacturers product you should at least be sure that your claim is correct. It's not. Please show me where Novak said that.
Rockpiledriver is offline   Reply With Quote
Old 08-16-2007, 08:21 PM   #11
Well here I go again!! I haven't even finished building my Super and I just ordered an AX-10!!
Here's what else I'll be using:
HPI Baja Bug body
Novak Goat combo
Hitec HS-645MG
Futaba Tx & Rx
Moabs
and now I'm going to have to add to my sig.......
mongoose is offline   Reply With Quote
Old 08-17-2007, 11:38 AM   #12
HPI Baja Bug body
Novak Goat combo
Hitec HS-645MG
Futaba Tx & Rx
Moabs
That right there is a great combo. One thing I would reccomend is at least a 5645 or even a 5955 servo. The Goat esc has more than enough BEC current to feed those higher torque servos no problem. I would take advantage of that.
Old 08-17-2007, 03:01 PM   #13
Thanks RPD.......check your orders from yesterday and you'll find out where I'm getting my AX-10 from. You guys are Novak distributors now? Do you know when you'll be getting the Goat combo in-stock?
Old 08-17-2007, 05:01 PM   #14
As soon as they are available from Novak we will have them. Should only be a couple of weeks now. Thanks for the order!
Old 08-20-2007, 07:22 PM   #15
Ok, since everyone else is doing it,
Scorpion
Novak xrs sport
Spektrum DX3.0
JR 126mg servo
Integy 55T lathe motor
Thats just stuff I had laying around the house cept for the servo and motor and scorpion, so It will be really cheap for me, just the price of the kit and a battery, not sure witch one though
Old 08-22-2007, 11:32 PM   #16
n/m
[I removed it for being off topic.]
Halfshaft is offline   Reply With Quote
Old 08-25-2007, 08:26 PM   #17
Exclamation
55T lathe + 20.00
$356.00
i have the same setup but with the rooster crawler
and i couldnt be happier
skoooter is offline   Reply With Quote
Old 08-27-2007, 08:55 AM   #18
I think I am paying more for the scorpion than all you guys, I got it from my lhs for $276 after taxes, I guess thats what I get for supporting my local guy
Old 08-27-2007, 09:41 AM   #19
Holy crap!!! Did he at least kiss ya when ya left?
I paid $239 out the door and im up here in canuck land where nothing is cheap!!!
bjornnson.. Youre gonna love this crawler. The only I see that may cause you some grief is the Bluebird servo....Around here a few boys have had them and they just dont last....End points set and all they just didnt last...Maybe they were just flukes, but steered clear of them.
TEAM-JCJ is offline   Reply With Quote
Old 08-27-2007, 09:46 AM   #20
No kiss or anything:-(
