08-01-2007, 01:31 AM | #61 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Here are 2 lower links ready to be assembled. They come with large set screws that you thread into the rod ends, then screw the rod end into the link. They got together real slick.
08-01-2007, 01:32 AM | #62 |
08-01-2007, 01:35 AM | #63 |
The uppers go together exactly the same way, but one end of each goes into the nifty 3 link rod end.
08-01-2007, 01:37 AM | #64 |
Here are all the links ready to be installed. Check out the sweet etching on the lower links. |
08-01-2007, 01:40 AM | #65 |
How do we stay up all night to bring you this great info you ask? Plenty of fig newtons and mountain dew, that's how. |
08-01-2007, 01:51 AM | #66 |
Rock Stacker Join Date: Jul 2007 Location: Sweden
i see that the color of the day is green both the laptop and the can goes bye the color of green i just made me some breakfast |
08-01-2007, 01:55 AM | #67 |
Newbie Join Date: Jul 2007 Location: Europe, The Netherlands
nice thread ! I'm following this build step by step By the way what's the time in your place , I'm from the netherlands (europe) and it's 10 in the morning over here ... ps. The color of the mountain dew matches the scorpion very well .... |
08-01-2007, 02:01 AM | #68 |
2am here, still building, uploading more pictures now.
08-01-2007, 02:16 AM | #69 |
Driveshafts go together next. Oh yeah, just like the Aluminum wheels hexes you also get plastic and metal driveshaft yokes. What does that other place charge for the metal driveshaft yokes we've all been using? They pop in just like any of the shafts we all use. |
08-01-2007, 02:23 AM | #70 |
Next up is the shocks. I won't bore you all with the details on how to put them together, you've all done it. Note that the shock come with Titanium Nitride Coated Shafts, those are about $8.00 a pair elsewhere. The springs seem a little stiff but we haven't put them on the rig yet, so time will tell. Axial offers 5 total spring rate options and all the rest are lighter than these. |
08-01-2007, 02:59 AM | #71 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
Those offset rod ends look very much like Kyosho Inferno 777 ST-R steering rod ends. (As illustrated in RC Driver September 2006 issue 33, pages 128-134, and referenced to on page 132 top right, under and right of Tech Tip, untweak your chassis). Oh yeah, great job! I know what my next build is going to be. mmmmmmm. Bearings and Aluminum included for under $350. Must.....have.....ccan't....tell.....wife.... Last edited by hvydty1; 08-01-2007 at 03:05 AM. Reason: I'm an idiot |
08-01-2007, 03:45 AM | #72 |
Getting closer... Take the axle assemblies that you have built, along with the links, and shocks, and put them all together. Slide the screw through the tab on the axle, then through the link, followed by a washer, then the shock and finally the other tab. Secure it all with a locking nut. Once thats done, hold the upper link into place and attach it with a single screw through the bracket on the axle. |
08-01-2007, 03:49 AM | #73 |
Both axles done, ready and waiting for a tranny and chassis to go together with.
08-01-2007, 03:51 AM | #74 |
All the tranny parts layed out, with some change thrown in for a size reference. This tranny is tiny |
08-01-2007, 03:52 AM | #75 |
ΜΟΛΩΝ ΛΑΒΕ Join Date: Dec 2006 Location: In tha Bush of Louisiana
i gotta go to work in 6 min hurry it up |
08-01-2007, 03:58 AM | #76 |
Pop the bearings in. Along with the gears and shafts. The top gear is metal the rest are plastic. All bearings though.
08-01-2007, 04:00 AM | #77 |
The center drive is locked by screwing the 2 outdrives onto the center gear of the tranny. Pop the bearings onto it and drop it into the tranny. |
08-01-2007, 04:03 AM | #78 |
Screw the tranny shut. And once again with a quarter thrown in for reference. |
08-01-2007, 04:07 AM | #79 |
Slide the GREEN spacers on and attach the motor plate. Note that Axial also offers another motor plate that allows small outrunner to bolt right up. The finished tranny. |
08-01-2007, 04:10 AM | #80 |
Bolt the tranny to the skid plate.
