Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Custom Build **Using Stock AX10 Axle and Tranny Kit**
Old 08-05-2007, 01:31 PM   #1
Rockpiledriver's Avatar
Default Custom Build **Using Stock AX10 Axle and Tranny Kit**
Noel and Brian have spent some time testing out the stock AX10 Scorpion kit and are very pleased with the results. Noel put together this build to show one way you can incorporate just the AX10 axle and tranny kits in addition to the stock links. Axial is manufacturing tranny and axle kits to go along with the Scorpion complete truck kit, for those that may not know.
1) Custom chassis to incorparate stock link positions, stock tranny and stock axles. Some of the aluminum in the middle of the Chassis beefy area will be removed to lighten it up. Some other minor adjustments will be made to the chassis and we are adding additional holes for different link and shock set ups.
2) Custom battery/servo mount
3) Custom Brushed motor.
We are going to test out a variety of upper and lower link postitions to see how it affects the performance.
__________________
Rockpiledriver is offline   Reply With Quote
Old 08-05-2007, 01:33 PM   #2
looks great
do you have the pictures in high res?
bjornsson is offline   Reply With Quote
Old 08-05-2007, 02:08 PM   #3
Originally Posted by M715ForLife View Post
thats sweet!
How wide is it?
Width is stock. You can get most of the stock dimensions from Jason's AX10 live build thread.
http://www.rccrawler.com/forum/showthread.php?t=79879
Old 08-05-2007, 03:58 PM   #4
Originally Posted by bjornsson View Post
looks great
Yes
Old 08-05-2007, 04:19 PM   #5
Are those internal spring shocks on that rig? How do you think that would work on ax10 rig?
tapped-out is offline   Reply With Quote
Old 08-05-2007, 04:54 PM   #6
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Should work the same as any other rig.
Harley is offline   Reply With Quote
Old 08-05-2007, 05:32 PM   #7
RCC green , Mamba Maxx green , Axial green .
This tranny looks like it will work great in an SW2 / 3
PROTOTYPE is offline   Reply With Quote
Old 12-07-2008, 01:08 AM   #8
now this is an old post
hyhflo is offline   Reply With Quote
