05-17-2008, 09:18 AM | #381 |
Newbie Join Date: Mar 2008 Location: falmouth
| that is the same thing i want to do with my AX10. The egde chassi and the rock crushers but should i get 2.2 or 1.9 size tires i want it to sort of look scale
05-19-2008, 06:56 PM | #382 |
Quarry Creeper Join Date: Oct 2004 Location: Canada eh!
| Red Bull
Well heres mine, Kit truck, Mamba max esc, MGT Setering servo, got rid of all the uguly green,(thanks oven cleaner) K9popo's sweet chassis, Integey motor, the axial axel mount to push the servo to the side, i got the stock rims and tires but i just put on som axial rims with rock Crusher's for a try. rear shocks are the from the kit, fronts, who knows ihad them kicking around and there the rigt size. well here ya go http://photos-c.ak.facebook.com/phot...41362_8780.jpg http://photos-e.ak.facebook.com/phot...41364_1594.jpg http://photos-f.ak.facebook.com/phot...41365_2934.jpg http://photos-g.ak.facebook.com/phot...41366_4316.jpg soon to have pics in action soon as the batts show up. |
05-20-2008, 01:28 PM | #383 |
Newbie Join Date: Jan 2008 Location: The Netherlands
| Defender 90 body on Axial with chassis
Finally my defender is ready? A defender is never ready........ Just want to show how it is now.:-P I'm trying to build my own 1:1 Defender only with soft-top. Scaled my home made winchbumper with warn winch (not working:-() Scaled decals like on big D90. Let me know what you think |
05-21-2008, 06:26 AM | #384 |
Newbie Join Date: Apr 2008 Location: Worcestershire, UK
My AX10 is my first r/c car ever, and I really love it I've been doing lots of reading and learning on this great forum, and am slowly learning I hope. I haven't done anything special with my AX10 - placed the spacers inside the shocks, split my 4200 stick into 3x pairs and mounted them over the front axle and front-upper links (bit of a squeeze ). I had great ideas for the paintjob until I realised just how difficult it is to mask the inside of a body shell - kudos to you guys who have wicked paintjobs Yesterday I tried my first bit of major body work - bob and dovetail. The first cut was the scariest lol. I had an idea for some simple tubework too - I found an old portable TV arial in the garage, and the largest tube looked about right for my rig, so I cut and chamfered the ends, made some plastic inserts from the plastic webbing from my AX10 kit and glued them into the ends of the tube. When they were dry I drilled and tapped them, then screwed through the body into the ends of the tubes. This makes the newly-cut rear of the body nice and rigid, PLUS I have no bolts showing where the back-end has been re-joined Not much, I know, but I'm pleased with it Spec: AX10 kit imported from USA Novak Rooster / 55T 4200mAh saddle-pack 4x 9/16 ball bearings in each front wheel Star-cut Axial foams Airtronics MX-3 r/c gear Used the 4-AA holder to mount the Rx between the rear-upper links I have some bent links on order, and then plan to use the old links for a 4-link conversion (in an attempt to get rid of the torque twist) |
05-24-2008, 02:41 PM | #385 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
Took a couple of "beauty shots" today: |
05-24-2008, 07:34 PM | #386 |
Newbie Join Date: Apr 2008 Location: 355th Fighter wing Davis-Monthan AFB
Nice
05-25-2008, 03:29 PM | #387 |
Newbie Join Date: May 2008 Location: Staten Island
edge chassis, Full droop suspension using modified t-maxx shocks and some very nice springs at the hardware store to use internally, stage 2 kit, 15Oz in front wheels, i put the batteries in the back for some weight, 55T motor and rooster crawler esc, I'm just waiting for my VF dig unit. Attached Images |
05-26-2008, 07:26 AM | #388 |
05-26-2008, 11:52 PM | #389 |
Rock Stacker Join Date: Dec 2005 Location: Socal
Mine, I it just got running.... |
05-27-2008, 12:56 PM | #390 |
Newbie Join Date: Jan 2007 Location: Oregon City
| I'm having a tough time bringing myself to mounting my batteries on the front axle or on the links - takes much away from the looks of the rig. This is my second AX10, so I've learned a little from the last - lowered the ride height by swapping the shock spacers to the inside of the shock body, moved the lower links inboard at the chassis with the Hot Racing skid plate. My only complaint is that it gets hung up easily since it's not that slick. I have added lead weight to the front axle, which made a BIG difference in how well the truck climbs. The heavy Proline wheels help, too. I added the CF chassis to help bring the CG down a bit, as well. |
05-27-2008, 01:12 PM | #391 |
Quarry Creeper Join Date: Jan 2006 Location: Spain
05-27-2008, 10:14 PM | #392 |
Newbie Join Date: May 2008 Location: Baton Rouge
| My babies. First run With LiPo. Novac rooster Crawler ESC and 55t motor. JR Z650m Servo. |
05-29-2008, 07:13 PM | #393 |
Newbie Join Date: Apr 2008 Location: Griffin
| My AX
I chose to go with Spectrum since they coat their electronics with a conformal coating making them water proof. I am also using rooster crawler ESC and Novak 55 turn crawler motor. Last edited by 666; 06-03-2008 at 08:05 AM. |
06-01-2008, 08:15 PM | #394 |
Newbie Join Date: May 2008 Location: Shreveport
my mostly stock RTR Cut foams traxxas endlinks venom 3000 pack |
06-01-2008, 08:16 PM | #395 |
Newbie Join Date: May 2008 Location: Rock Hill, SC
| Rock Whisperer
Getting better at the painting...still not up to snuff with the awesome stuff I see on here. Click here to view the final product... Equipment list: Stock Axial Kit, bump stops moved inside shock housings, star-cut stock foams Integy 45t motor CC Sidewinder 6-cell saddle-pack (on order) Had it out on the rocks only once naked [the truck, not me ] and was VERY impressed. I already have a long list of mods to make |
06-01-2008, 08:39 PM | #396 |
Newbie Join Date: May 2008 Location: Australia
Heres my rig, after a muddy crawl. |
06-02-2008, 05:39 PM | #397 |
| A few of mine getting wet.... Last edited by 666; 06-03-2008 at 08:05 AM. |
06-02-2008, 07:38 PM | #398 |
Newbie Join Date: May 2008 Location: Singapore
Here's a few pics of mine testing it out... And here's some of us crawling in SIngapore... |
06-03-2008, 07:46 AM | #399 |
Newbie Join Date: May 2008 Location: Arlington
06-03-2008, 07:56 PM | #400 |
Newbie Join Date: May 2008 Location: sulphur
hers mine nothing special right now . upgrades so far, tmaxx rear turnbuckles for lower links, cut stock foams, drilled wheels, upgrades in the mail, novak 55t, rc4wd rock crusher x/t 2.2 tires with memory foam, rooster crawler esc, axial aluminium steering components, new body, |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/82403-axial-ax-10-picture-archive-no-talking.html | ||||
RE: Anyone Have a Mini MGT? | This thread | Refback | 10-05-2011 08:59 AM |
Axial AX-10 Picture archive - No talking - Similar Threads | ||||
1.9 scale rig picture archive - No talking | 123abc | 1.9 Scale Rigs | 2041 | 03-26-2024 03:44 AM |
Redcat Picture Archive - No talking | EeePee | Redcat Crawlers | 404 | 02-08-2024 06:23 PM |
1.5 scale picture archive - No talking | 1BadJeepBruiser | 1.5 Scale Rigs | 358 | 07-04-2023 03:22 PM |
SCX10 Picture Archive - No talking | BENDER | Axial SCX-10 | 3332 | 06-04-2023 05:40 PM |
Wraith Picture Archive - No talking | Harley | Axial Wraith | 1586 | 03-22-2023 11:32 AM |
