Thread: Axial AX-10 Picture archive - No talking
Old 10-01-2009, 04:37 AM   #961
jreckner is offline   Reply With Quote
Old 10-06-2009, 05:34 PM   #962
NorKalKushKrawler is offline   Reply With Quote
Old 10-08-2009, 05:27 PM   #963
Finally done!
Scorpion cut with knife on fascolor masking tape...
markusb is offline   Reply With Quote
Old 10-09-2009, 09:25 PM   #964
Default my ax10
my ax10.....so far
-built stock with CKRC st2 suspension kit.
-YEAH RACING knuckles both ends
-STRC c-hubs both ends
-TEKIN fx-r esc
-HPI x-75 motor
-SPEKTRUM dx5e radio gear
-VENOM 4200nimh battery over front axle
-d.i.y aluminium front battery/servo mount with 4 link mounting
-d.i.y aluminium rear servo mount with 4 link mounting
-d.i.y aluminium chassis plates
-d.i.y stainless steel tranny plate
-INTEGY drive shafts
-AXIAL 43/13 ring&pinion in both diffs
-92 spur 14 pinion
-no-name EBAY mg995 servos (i know, i feel dirty using them)
-PROLINE hammers due to go on rims when stock tires die.
-stock shock bodies inverted, usng springs from ball point pens internally for droop and externally for up-stroke. 40wt oil lets it twist lovely.
considering new steerng link set-up and adding thin stainless sheet-metal to diffs for better slidding over rocks. no such thing as box stock....
slowlearner is offline   Reply With Quote
Old 10-09-2009, 11:24 PM   #965
Here's a couple of my scaler(work in progress, aren't they all?)
Integy Knuckles and one piece rears
Integy 60T motor
Novak Reversible ESC
Integy DS
PL Western Bumpers, frame extension kit, vertical body mount kit, Roof Rack, Light Bar, and accessory packs 1&2
73 FORD Bronco Body
Futaba Magnum Junior Radio and servo
BLOODBANE is offline   Reply With Quote
Old 10-10-2009, 11:52 PM   #966
Default Some newer pics
Here is a few after restackin the rock pile.
Yeah had to play with both on the rocks.....
cant really tell from this angle but she's hangin on two tires..... and yes i drove it here!
rugerboy is offline   Reply With Quote
Old 10-11-2009, 06:37 PM   #967
I joined the Band!
Default My ax-10 comp
Truck Base : Axial
Frame: MFM Black Widow
ESC: Castle Creations Mamba Max
Motor(s): Intengy 55 Turn V10
Servo(s): Hobbico CS-170 Std Digital Ultra Torq 2BB TG
Trans: R2D with Dig
Axles: Axial with heavy duty lockers
Tires: Cougers
WB: 12.5
Center Chassis clearance: 2.25 in
Steering: CKRC BTA Kit
Battery: 3 cell lipo
Body: Proline 72 chevy
Shocks: Full droop with ckrc inner springs
Other Goodies:
RockHound R/C :-D Delrin links
RockHound R/C :-D Delrin skid plate
RockHound R/C:Wheel weights
Golden Horizons Aluminum Knuckles
Golden Horizons Alum C Hub Carriers
TCS 4 Link in rear
vdubman is offline   Reply With Quote
Old 10-12-2009, 02:54 PM   #968
Black link conversion, 4 bent lowers
soft springs, rears mounted to the outside to fight torque twist.
stock everything else for now. $$$
http://www2.snapfish.com/slideshow/A...NAME=comcast2/
Pointman is offline   Reply With Quote
Old 10-13-2009, 11:59 PM   #969
Default My AX-10
Nothing special no real mods done as of yet but working on it.
Integy 65x1 motor
Spektrum SR3000RX
DS 1015 Ace RC Digi Steering Servo
4200 Flat Pack for now but hopefully soon will be replace for a more conventional style battery.
Traxxas WP XL 5
W/ Spektrum DX 2.0
http://img390.imageshack.us/gal.php?g=1000963.jpg
Picture is when i first got it since then changed springs out with HPI springs and a lower belly skid.
Mechinary is offline   Reply With Quote
Old 10-14-2009, 06:06 AM   #970
Default Here's my AX-10
finally! it came in...my AXIAL AX-10...this thing is awesome the first time i drove it inside my house crawling over everything and anything...
i would tell you guys what it has...maybe you guys can see for yourself...
enjoy!
Christopher D is offline   Reply With Quote
Old 10-16-2009, 02:28 PM   #971
ax 10 with black widow chasis has all the alum fornt an rear cs an lockouts 55 turn motor with a crawl speedo losi shocks belly is at 2 1/2
slowride1 is offline   Reply With Quote
Old 10-20-2009, 10:46 AM   #972
Axial/RC4WD Diablo .
The stats:
Axial axles (locked/w front overdrive gears)
Axial trans with HR S.S. locker
Axial bent links
RC4WD Diablo chassis (thanks RC4WD!)
Team Zero shocks, inverted and internally sprung
Novak 55T motor
RC4WD RPP Limited Edition beadlocks (center caps not shown)
CC Sidewinder ESC
Maxamps 1600 2/3A 8 cell
Hi-tec HS5645MG servo
Hot Bodies Rovers (white compound)
Axial XC-1 body
TrailDawg362 is offline   Reply With Quote
Old 10-20-2009, 11:30 PM   #973
Talking
my ax 10s Name:  rock crawling 053.jpg
Name:  rock crawling 001.jpg
Name:  rock crawling 006.jpg
Name:  rock crawling 007.jpg
Name:  rock crawling 016.jpg
Name:  rock crawling 018.jpg
Name:  rock crawling 043.jpg
John Crosthwait is offline   Reply With Quote
Old 10-22-2009, 08:05 AM   #974
my axial rig, my first crawler.
AX10 artr
novak rooster and 55t motor
HR dig
weights in wheels
3RACING trans-box
replacemented springs(more soft)
MG995 servo
chester chen is offline   Reply With Quote
Old 10-22-2009, 01:21 PM   #975
Here is Scorp!
SWX Chassis
Goat Crawler esc w/17.5 brushless
2.2 LiPo
Dual Stearing Servo's
Mirrored Trans
14 tooth Pinion
Overdrive In Front Axel
prophetz is offline   Reply With Quote
Old 10-25-2009, 12:48 AM   #976
mine.
ax-10 art
novak rooster crawler esc
novak fifty-five
rrp 93t spur
rrp 21t pinion
tcs delrin tranny plate that moves the link to the inside of the chassis
rpm revoler narrow wheels
losi crawler tires. the ones that look like the pitbull rocker 1:1 tires
hitec metal gear servo
airtronics radio.
proline blazer body. with bedliner paint job to match my 1:1 blazer
proline frame extender
proline bumpers
3racing winch
aluminum front knuckles
mip splined drive shafts
pics when i first got it. all pics were taken in iraq. i did all this while i was deployed there for a year.
74blazerboy is offline   Reply With Quote
Old 10-25-2009, 12:59 AM   #977
pics of it with the blazer body
and the full size ride it was modeled after.
and to prove its not a pavment princess
Old 10-26-2009, 07:18 PM   #978
It was done
slow1 is offline   Reply With Quote
Old 10-28-2009, 06:39 PM   #979
My Axial Scorp with a Pro-Line Tube body..
27 turn 550 motor
3300 NiMH 6 pack
Novak Rooster Crawler
HiTech RX
HiTech 645MG servo
2.2 MudSlingers
Stock shocks with soft springs and 70wt oil
14/88 gears with HR Alum spur and trans gears
orange-appeal is offline   Reply With Quote
Old 10-29-2009, 09:00 AM   #980
nice cars !
Bolt up is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/82403-axial-ax-10-picture-archive-no-talking.html
Posted By For Type Date
RE: Anyone Have a Mini MGT? This thread Refback 10-05-2011 08:59 AM
Axial AX-10 Picture archive - No talking - Similar Threads
1.9 scale rig picture archive - No talking 123abc 1.9 Scale Rigs 2041 03-26-2024 03:44 AM
Redcat Picture Archive - No talking EeePee Redcat Crawlers 404 02-08-2024 06:23 PM
1.5 scale picture archive - No talking 1BadJeepBruiser 1.5 Scale Rigs 358 07-04-2023 03:22 PM
SCX10 Picture Archive - No talking BENDER Axial SCX-10 3332 06-04-2023 05:40 PM
