Thread: Axial AX-10 Picture archive - No talking
Old 11-27-2009, 12:14 PM   #1001
JLF
Default My 'SCORPION KING' Project!
My 'SCORPION KING' project. I love Clodbusters and Scorpions, so I decided to mesh both worlds and make a modern day Clod. Its a work in progress, and is constantly evolving. Bigger, more Alloy, and next, Huge Brushless Power!
JLF is offline   Reply With Quote
Old 11-27-2009, 11:32 PM   #1002
Well here is my AX10. Started as a kit and now I have almost a complete truck in left over parts after upgrades.
DNA Slingshot
DNA 2.2 Beadlocks
DNA Dig
Losi 4" Shocks
CC BEC 6.2v
Junfac SS Driveshafts
HR Straight axle kit
Tekin FXR 35T
HB Rovers
Nova's ark dual stage foam
AgentXXX is offline   Reply With Quote
Old 11-29-2009, 07:04 AM   #1003
Default Brazilian scorpion
Hello everybody...
My name is Bill. I live in Curitiba, Brasil and this is my AX10.
First i made a body with aluminum bars and plastic parts...
After i made other body with aluminum only, and fixed batteryes in the side of chassis for more stability...
Bill Br is offline   Reply With Quote
Old 12-02-2009, 06:37 PM   #1004
Here's mine in it's cutant state. How long it will stay this, who knows.
Started with ax10 kit
changed out the chassis for the Bender swx kit
using inverted Max shocks all the way around
panther leopards
novak rooster crawler esc and 55t motor
futaba 3pm 2.4gig
hobbico cs 170tg
hot racing dig
great planes 1600mah lipo
JConcepts Stage Killah
pic of before swx
as it runs now
mr.freeze is offline   Reply With Quote
Old 12-05-2009, 06:52 PM   #1005
My crawler. I don't comp, yet. I'm getting the bashing part out of my system first, and learning to tune the RIG and drive better.
AX-10 4ws no dig
Alu C's & knuckles (front) overdrive R&P
stock (rear) HD R&P
FX-R, 3s 1500mah, Titan 21T (87t s 12t p)
ccbec @ 7.2V
JR ds8611a (front) CPE-SER4: CYS (rear)
4 link front & rear
30* links
stock shocks semi-droop (60wt f & 80wt r)
TQ2.4 4Ch
RIG_RIDER is offline   Reply With Quote
Old 12-07-2009, 02:35 PM   #1006
sorry
mik3sparks is offline   Reply With Quote
Old 12-08-2009, 12:36 PM   #1007
Default My crawler
It is amazing to see all of the different variations of one crawler model.
Here is my basher rig that is nearly comp legal (illegal body). I just finished the rig a few days ago. I wanted a different body that wasn't a bug. Next body will be Proline's 72' chevy C 10. The drive shaft broke yesturday, (first day out after rebuild) will be replacing it with T maxx shafts.
SPECS:
Servo: hitec 7955tg
Servo mount: Home made out of AL
Battery: Hand built 2/3a 1500 nimh 8 cells with Sermos
Tires: Panther Cougars with axial stock foams
BTA by Jet boat
Wheels: stock with some weight in the front only (for now)
Knuckles: Rd logics
Cvds: 3Racing
Shocks: HR 100mm Air shock
Links: Home made plastic with allthread and revo ends
Chassis: TK Twister small T bone
Body mounts: home made
BEC: Castle Creations
Radio: Ko Propo EX-5UR
Motor: Custom hand wound 55T Double
Stock gearing for now
Esc: Castle Creations Mamba Max with 12awg wiring
Lockouts: Home made
Body: An old HPI/Tamiya Mini Cooper (old school)
Topless
Flexin
Drop off
racerfred is offline   Reply With Quote
Old 12-08-2009, 07:23 PM   #1008
Default My rig
THIS IS MY AXAIL AX-10. I AM USING THE T-MAXX TIE RODS FOR MY REAR 4-LINK AND FRONT LOWER LINKS. IT ALSO HAS PANTHERS MOUNTED ON AXIAL ROCKSTAR BEADLOCK WHEELS WITH GREEN LOCK RINGS. FOR BATTERY POWER I AM USING 1500MAH 7.2 VOLT HUMP PACKS WHICH ARE MOUNTED ON THE FRONT AXLE.
I CRAWL AT THE CONCORD, CA HOBBYTOWN JUST ABOUT EVERY SATURDAY. IF I'M NOT THERE I'M USALLY UP AT MY 40+ ACRE PROPERTY MAKING CRAWL AREAS.
CRAWL ON!!!
ChevyAX-10 is offline   Reply With Quote
Old 12-08-2009, 10:06 PM   #1009
Just picked up my buddies ax10. So far Ive already put a 2s goat esc and a modified jeep body. Other than that its got bent links in the rear, 55t integy motor, 1500mah split battery pack on the front axle, rc4wd rock crusher tires on axial beadlocks, and a hitec hs645mg servo. Soon to come is a droop only setup and brushless and lipo.
flaco is offline   Reply With Quote
Old 12-10-2009, 04:46 AM   #1010
Right out of the box, still has that new crawler smell.
WVhillbilly is offline   Reply With Quote
Old 12-11-2009, 10:21 AM   #1011
Some picks of my C-10 covered Bastard jr. I shortened up the wheel base with some custom links from R2j, and a double tri skid. now sits just over 11"s. I notched the C-10's rear bed and window to fit it over the Bastard jr tube chassis.
Krakker is offline   Reply With Quote
Old 12-14-2009, 03:17 PM   #1012
My Axial:
Underground crawlers F-4 chassis
Custom links
Custom Front/Rear 4-links
Tekin FXR w/ 55T
Hitec 645
HB Rovers(white) on axial rims
Bmarsh is offline   Reply With Quote
Old 12-14-2009, 03:34 PM   #1013
Default my ax 10
http://www.facebook.com/photo.php?pi...&id=1077604440
this is my ax 10 it has a ckrc bug body 55t motor and rooster esc with a futaba pm3 radio
cklanish88mj is offline   Reply With Quote
Old 12-14-2009, 03:50 PM   #1014
Default my ax 10
Old 12-14-2009, 06:25 PM   #1015
MFM Black Widow chassis
Mayhem Spiders w/ Mayhem Custom rings
HB Rovers (white) w/ stock foams
J Concepts Rock Steady body
HR dig w/ Airtronics 94102 servo
Axial axles
JR DS8711
Integy 45t lathe motor
Delrin lower links F/R
Delrin upper 4 linked rear
Stock upper 3 link front
Mystery shocks/ full droop
DonsATV is offline   Reply With Quote
Old 12-22-2009, 11:16 PM   #1016
dranger962000 is offline   Reply With Quote
Old 12-30-2009, 12:40 PM   #1017
Default my crawler
this is my crawler !
ax10 whit badstard jr chassis
mamba max esc
outruner brushless
proline tire whit junfac wheel
mg946r servo
2x 1400mah
maxpearl is offline   Reply With Quote
Old 12-30-2009, 05:25 PM   #1018
Default Complete one-off build
100% Designed, built, and machined by me, utilizing Solidworks and Mastercam.
Novak Goat Brushless system
2s lipo
HPI Rock Grabbers
Spektrum DX6i
One-off chassis, servo/battery mounts, electronics tray, beadlock rings, etc programmed and machined by me.
CnC Kid is offline   Reply With Quote
Old 12-31-2009, 01:06 AM   #1019
AX10 with Losi springs (2.3 rate front; 2.6 rate rear). Novak Rooster Crawler/55t combo, Hitec 645MG servo. Custom front steering linkage for added clearance, hi-clearance links rear, rear 4link setup, stock tires.
And a short running vid 4 fun!
http://www.youtube.com/watch?v=nCMccfDoeGA
morguester is offline   Reply With Quote
Old 12-31-2009, 04:29 PM   #1020
hodge is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/82403-axial-ax-10-picture-archive-no-talking.html
Posted By For Type Date
RE: Anyone Have a Mini MGT? This thread Refback 10-05-2011 08:59 AM
Axial AX-10 Picture archive - No talking - Similar Threads
1.9 scale rig picture archive - No talking 123abc 1.9 Scale Rigs 2041 03-26-2024 03:44 AM
Redcat Picture Archive - No talking EeePee Redcat Crawlers 404 02-08-2024 06:23 PM
1.5 scale picture archive - No talking 1BadJeepBruiser 1.5 Scale Rigs 358 07-04-2023 03:22 PM
SCX10 Picture Archive - No talking BENDER Axial SCX-10 3332 06-04-2023 05:40 PM
