10-04-2010, 08:54 AM | #1161 |
Rock Stacker Join Date: Sep 2008 Location: Eastern Oregon
| DMG on Poulson Axles
Some used stuff I picked up. The DMG Alluminiti from Greece, and some Poulson Axles from Zorlac, YA the DMG guy. But really the only AX10 thing left is the trans. Stock trans Metal Gears VP Hurtz Dig Tekin FXR Novak 45T CC BEC 3s Lipos MIP Shafts Poulsons JR8711 steering Losi Shocks RC4WD Wheels PL Chisels |
10-04-2010, 08:01 PM | #1162 |
Rock Stacker Join Date: Sep 2010 Location: Denver
Are they ever complete? novak rooster, novak 45 turn, self built tube frame, spektrum dx3e radio, reciever, and servo robinson racing output gear, pro line flat irons (sedonas are on the way) home built battery tray(have since cut up and resoldered battery packs into saddle packs but don't have a new pic) high clearance knuckles, integy piggybacks,(they need to be replaced with something shorter) It still needs the tranny pan to be switched to delrin and a lot of other stuff but it is loads of fun as it is and a far cry from the rtr it was a few weeks ago. |
10-06-2010, 11:14 PM | #1163 |
Quarry Creeper Join Date: Jul 2010 Location: Saraland
| my ax10 scorpion
here is my mostly stock ax10 scorpion
10-08-2010, 07:21 PM | #1164 |
Rock Stacker Join Date: Mar 2010 Location: Oak Harbor
this thread makes my heart go pitter patter
10-08-2010, 09:30 PM | #1165 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
My AX10 Kit truck Novak rooster crawler esc Novak 55t motor Venom power li-po JR 8711 front servo traxxas 2075 rear servo (soon to be changed) Spectrum DX3E radio Tamiya light unit with custom light buckets and spot lights. GoPro Hero camera. |
10-08-2010, 09:42 PM | #1166 |
| Herbie Rally Edition
STRC Aluminum Knuckles, C's, and rear lock outs STRC 4 link Rear OD Front UD Rear Robinson Steel Internal Gears MIP C Splines Sidewinder on 3S CC BEC Hitec 7955TG @ 6V VP Incision Pro Chassis DNA Thrashers 2.2 HB White Dot Rovers Proline Dual Stage Memory Foams R2J Delrin lowers Losi 4" Comp Shocks on Gold Springs 45wt Spektrum 2.4Ghz SR3100 Proline Bug Body Herbie Rally Scheme Last edited by alexchen86; 10-08-2010 at 09:44 PM. |
10-09-2010, 05:16 PM | #1167 |
Quarry Creeper Join Date: Oct 2008 Location: Valley Village
| AX-10 MoonBuggy
Thanks, Mike! |
10-10-2010, 06:02 AM | #1168 |
Newbie Join Date: Sep 2010 Location: Columbus
| my first crawler
It's work in progress. But I am satisfied with it so far |
10-10-2010, 02:26 PM | #1169 |
Newbie Join Date: Aug 2010 Location: santa rosa
Heres mine, picked it up used for $250, put another $200 or so in it so far (including radio) Specs --Spectrum DX3E 2.4ghz.radio --Overdriven front steel bevel gearset 14t/36t --Stock ratio rear steel bevel gearset 13t/38t --Vent holes drilled in rims --Battery relocated to back axle --Around 1.5lbs of screw in wheel weights on front --Around 1 lb of screw in wheel weights on back --Futaba heavy duty metal geared servo --Fast lane machine Heavy duty rear spool with set screws --STRC heavy duty Steel rear lock out axles --Full droop setup on shocks so link bars are parallel to the ground --All aluminum Integy link bars, steering, and driveshafts --Racers Edge Aluminum Pro Adjustable Servo Horn --Integy brand shocks --Transmission upgraded to all steel geared and pinioned Integy kit --3racing Aluminum transmission housing --3racing Aluminum steering knuckles --Novak 55t motor --Rooster crawler ESC --Inboarded lower links --Outboarded shocks --Aluminum lock on wheel hexes --Aluminum axle end upper link mounts --Aluminum lateral braces --Aluminum servo mounts --Venom creeper wheels --Front tires are Pro-line chisels 2.3" wide by 5.4" tall --Rear tires are Hpi racing Rock Grabbers 2.3" wide by 5.4" tall - - - |
10-11-2010, 08:54 AM | #1170 |
Newbie Join Date: Sep 2010 Location: Orange County
| David's Axial Ax10 :D
Hi im David from the Philippines id like to share with you my Axial Comp Spec Rig?lol..Im VERY NEW to Crawling so please bear wih me Heres my newbie set-up Heres my set up: Ax10 Kit Carbon Fiber Chassis Lots of STRC Upgrades Tekin 55t Motor Tekin Fxr Esc 2s 1350mah lipo Tamiya Servo (waiting for my hi-tec) Losi Claws Beadlocks DNA Dig (waiting for its servo din) 2.4ghz Radio Aluminum Shocks Please comment and let me know what else do i need. Thanks!! Last edited by bentoy101; 10-11-2010 at 08:56 AM. |
10-11-2010, 01:15 PM | #1171 |
Newbie Join Date: Oct 2010 Location: US
All dressed up and then in a beater body.... Stock except for four-way steering. When it stops raining I will get some more climbing pics. |
10-11-2010, 02:41 PM | #1172 |
Rock Stacker Join Date: Jul 2010 Location: DFW
Got mine used for $150 without an ESC, popped in a Novak Rooster! Then got a TCS edge Chassis, picked some Losi Claws on RCC for cheap. Also have some 4 link front and rear and a newly flipped tranny! |
10-14-2010, 10:40 AM | #1173 |
more pics of my ax10 in action in bay st. louis.ms.
10-18-2010, 03:32 PM | #1174 |
Pebble Pounder Join Date: Jul 2010 Location: Nor*Cal
Nothing special....... I haven't painted a body in a few decades, it came out ok. Last edited by squirrel886; 10-18-2010 at 03:35 PM. |
10-23-2010, 09:06 AM | #1175 |
Rock Stacker Join Date: Jan 2005 Location: I come from the Land Down Under....
custom chassis/tubes/rear steer play thing and the in the project comper.. |
10-23-2010, 12:20 PM | #1176 |
Newbie Join Date: May 2010 Location: deerfield beach
| beach crawlers |
10-24-2010, 05:54 PM | #1177 |
Rock Crawler Join Date: Feb 2010 Location: Paw Paw, MI
Welp, My AX10 has changed once again. It only had this body for a month or two And then I couldn't help myself (after a failing attempt at building an exo truggy) from buying the Pro-Line Tuber Since these pics were taken a few days ago, I made a 'hood' for the buggy, to make it more pleasing to look at! |
10-24-2010, 08:21 PM | #1178 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
Just realized Ive never added to this archive. Happy to say this rig took home a first place finish at our clubs last point series and it was the highest placing Axial at the battlegrounds 2010. Too many things to list for upgrades and mods so pm for any questions or closeups of anything. I'm not going to clutter this thread with a ton of pictures. |
10-25-2010, 12:16 PM | #1179 |
Rock Stacker Join Date: Jul 2010 Location: canada
here is a link to pics of my ax10. and of my slash 2wd. http://www.ultimaterc.com/gallery/index.php?cat=58576 |
10-26-2010, 12:13 PM | #1180 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
The latest incarnation of my rig.....
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/82403-axial-ax-10-picture-archive-no-talking.html | ||||
RE: Anyone Have a Mini MGT? | This thread | Refback | 10-05-2011 08:59 AM |
Axial AX-10 Picture archive - No talking - Similar Threads | ||||
1.9 scale rig picture archive - No talking | 123abc | 1.9 Scale Rigs | 2041 | 03-26-2024 03:44 AM |
Redcat Picture Archive - No talking | EeePee | Redcat Crawlers | 404 | 02-08-2024 06:23 PM |
1.5 scale picture archive - No talking | 1BadJeepBruiser | 1.5 Scale Rigs | 358 | 07-04-2023 03:22 PM |
SCX10 Picture Archive - No talking | BENDER | Axial SCX-10 | 3332 | 06-04-2023 05:40 PM |
Wraith Picture Archive - No talking | Harley | Axial Wraith | 1586 | 03-22-2023 11:32 AM |
