10-26-2010, 06:36 PM | #1181 |
Quarry Creeper Join Date: Jun 2010 Location: NIXA
| fallin aparts ax10
ax10 with novak 55t motor and esc, bent lower links, hb rover tires, hi tech steering servo, vw body and traxxas 3ch. radio |
10-26-2010, 11:49 PM | #1182 |
Newbie Join Date: Oct 2010 Location: Saint Louis
I have only owned this truck about 4 days, won it in a contest from the LHS, RTR, not ready to crawl.... I am making changes as quickly as I can, the first to get replaced was all that plastic crap, and the POS motor......Diff lock, Tranny mirror, Foams cut, Wheels drilled, All aluminum Kit, plus new servo gears, and horn...... |
10-29-2010, 11:38 AM | #1183 |
Quarry Creeper Join Date: Oct 2010 Location: McKinney
I started out with an ARTR AX-10 and did a couple minor upgrades: Then I upgraded to Underground Crawlers Fastback chassis: and after a few more upgrades, this is where I stand now: Semper Fi! |
10-31-2010, 02:25 PM | #1184 |
Newbie Join Date: Jun 2010 Location: Palmer
11-05-2010, 10:01 PM | #1185 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
Here is my AX10 and a list of mods. (Some mods not pictured) Axial AX10 scorpion ARTR kit. Gatekeeper chassis kit. integy aluminum wheels integy aluminum transmission housing VF/DNA dig unit with Steel internals All robinson racing metal gears with plastic spur MIP drive shafts CVD MIP axle shafts CVD Aluminum C hubs and knuckles Aluminum Rear axle lockouts and steel driveshafts Integy HD pinion and bevel gears. Titanuim lockers HItec digital steering servo with titanum gears(ultra tourge) Hitec might mini dig servo axial aluminum steering links Slick sleeves spektrum DX3R and receiver Losi aluminum 4" comp shocks Novak crawler motor 18.5 Novak crawler goat ESC Motor mount with cooling fins Novak fan on esc 2 Max Amps 2S LIPO's 2000 Mah carbon fiber battery mount with REI strap. Losi Grappler body HB Rover tires (White) HR slipper clutch removal kit. Losi Night Crawler LED Light kit. Aluminum steering servo horn Last edited by TedBull; 11-05-2010 at 10:04 PM. |
11-09-2010, 09:01 AM | #1186 |
Rock Stacker Join Date: Feb 2010 Location: st. Albans Wv
my ax10 ive had since march its my first crawler build |
11-10-2010, 02:20 AM | #1187 |
Pebble Pounder Join Date: Oct 2010 Location: Maui, Hawaii
Soon to have a bronco body: soon to have a t runner body and upgraded electronics Soon to have a hi Lux or Cherokee body All purchased off of the local craigslist for cheap |
11-11-2010, 12:45 PM | #1188 |
Newbie Join Date: Nov 2008 Location: Delaware
Here's mine so far: AX10 kit SWX chassis Losi Shocks Losi tires (Now swapped to Panther Leopards) VP DH Comps VP Hurst Dig with Mighty Mini Servo 4-link rear Bug Body Mamba Max CC Bec set to 6V Hitec 7955 HH 45T Motor 1300 Mah 11.1v 3s LiPo DX3R Last edited by Yama86; 11-23-2010 at 04:52 AM. |
11-11-2010, 03:17 PM | #1189 |
Newbie Join Date: Oct 2010 Location: victoria
here are some great pics of my ax10 scorpion rtc with 55t moter and 90t spur as well a 13t pinion. the tires are imex all-t dawg tires and are 5.5" tall and 3" wide hope you enjoy my pics |
11-12-2010, 05:58 PM | #1190 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
My 2 axial based rigs |
11-16-2010, 08:01 PM | #1191 |
Newbie Join Date: Oct 2010 Location: Pennsylvania
Here she is |
11-16-2010, 10:27 PM | #1192 |
Newbie Join Date: Jul 2010 Location: camarillo
My ax10 ARTR Complete budget build mod list: Homemade dig Stick on wheel weights in all wheels (18oz front & 10oz rear) Proline chisel tires Center skid plate modified to move lower links inboard Shock limiters inside & outside shockbodies (team associated plastic shock internal spacers) Team associated rear shock springs (blue front & red left rear gold right rear) Tekin FXR & Tekin 55 turn Hi tech mg servo Front axle aluminum upgrades to come. Not a full blown comp rig, but gets the job done. Lots of fun! |
11-17-2010, 06:57 PM | #1193 |
Newbie Join Date: Oct 2010 Location: US
Just put on my JConcepts Gate Crasher Body on, as well as some bent linkages.... the paint is actually black with gold flecks, it really shines in the sunlight. Raining outside right now hence quilt pic. |
11-18-2010, 10:15 AM | #1194 |
Newbie Join Date: Nov 2010 Location: Middle Tennessee
Heres my rig, and all the essential information. Gatekeeper Chassis, with custom made links CKRC behind axle steering CKRC high steer knuckles DNA Dig TCS boomerang 4 link mount CCBEC Tekin FX-R ESC Hand wound motor Airtronics 94780 steering servo Hitec hs-645 dig servo Spektrum DX3-R Spektrum S3300T |
11-18-2010, 04:24 PM | #1195 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
Trail ready.... Bronco with all scale proline stuff. Diff wheel package as well It takes about 20-30 mins to change everything back to this setup Lol |
11-25-2010, 04:26 PM | #1196 |
Newbie Join Date: Nov 2010 Location: Folsom
11-30-2010, 04:07 AM | #1197 |
Rock Stacker Join Date: Nov 2010 Location: nunya
| my ax10 rtc
started out as a rtc but ive modded with longer shocks it gets more the 100 degrees of flex when twisted by hand but will flex about 75-80 on its own with all four on the ground, four wheel steering costom high clearance steering in the front,traxxas half shafts which are stronger,xl5 speed control, 27 turn epic silver can motor geared 13/87 and a tower hobbies 7/8 channel receiver for the rear steer and future front and rear dig unit. 5 oz. of 3/8" airsoft bbs in each front tire,star cut foams in rear with grooved hammers,every other lug all the way across in rear and every other outer lug in the front, 10th scale bolink baja bug body painted pearl purple with silver backing stock servos for now as im still in the testing phase of my build |
12-01-2010, 09:22 PM | #1198 |
Quarry Creeper Join Date: Jul 2010 Location: Saraland
| ax10
my latest ax10.all blue links. bent lower links. 4 link uppers.dynamite blue chassis side plates.flipped blue aluminum shocks.intergy 55 turn motor mounted to a clodbuster adjustable motor mount with 10 tooth pinion.hot racing dig unit.traxxas 2.4ghz 3 channel rx&tx.new proline bug body.hb rovers.hitec 645 dig servo.200 in oz. steering servo. |
12-01-2010, 09:55 PM | #1199 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
Mayham double phattys, rears are delrin, Double Deuce Nova foams, Rover white dots, MIP CVDs, MIP Driveshafts, Sportwerks shocks. CC BEC, CC Mamba Max, Hitec HS-7955MG, HH 7t Colbalt Puller motor, VP Zero Ackermann knuckles, Jones'N BTA, Spektrum DX3E. Runnnig a DNA SlingShot chassis with Delrin lower and upper links. Last edited by Wicked Klown; 03-27-2011 at 09:18 PM. |
12-03-2010, 01:15 PM | #1200 |
Newbie Join Date: Jul 2010 Location: Sacramento
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/82403-axial-ax-10-picture-archive-no-talking.html | ||||
RE: Anyone Have a Mini MGT? | This thread | Refback | 10-05-2011 08:59 AM |
Axial AX-10 Picture archive - No talking - Similar Threads | ||||
1.9 scale rig picture archive - No talking | 123abc | 1.9 Scale Rigs | 2041 | 03-26-2024 03:44 AM |
Redcat Picture Archive - No talking | EeePee | Redcat Crawlers | 404 | 02-08-2024 06:23 PM |
1.5 scale picture archive - No talking | 1BadJeepBruiser | 1.5 Scale Rigs | 358 | 07-04-2023 03:22 PM |
SCX10 Picture Archive - No talking | BENDER | Axial SCX-10 | 3332 | 06-04-2023 05:40 PM |
Wraith Picture Archive - No talking | Harley | Axial Wraith | 1586 | 03-22-2023 11:32 AM |
