Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: didnt think going slow would be so much FUN!!!
Old 08-24-2007, 12:19 AM   #1
Cool didnt think going slow would be so much FUN!!!
Built my axial and started playing w/ it, This thing rocks!! build was way easy, quality is top notch. I am running a 55t, futaba ESC, 645mg servo, everything else is stock. Thing is way cool works awsome Just have one question. I'm going to order a crawlmaster and want to know how well it works w/ the mamba 25, 14t pinion, and 6cells. Buddy has one in his hilift and works awsome but hes runnin a quark and 3s lipo. Just curious if any you guys have any insight on how the mamba 25 works w/ the crawlmaster. Thanks guys!!
scatterbrains is offline   Reply With Quote
Old 08-24-2007, 01:24 AM   #2
It will suck on 6 cells, i ran a crawlmaster on 8 cells and it still wasnt enough voltage for good performance A lipo will defintely wake it up, but i dont think the mamba 25 will be very happy
dittohead is offline   Reply With Quote
Old 08-24-2007, 08:44 AM   #3
It's the most fun I have had with clothes on!
FrankyRizzo is offline   Reply With Quote
Old 08-24-2007, 10:31 AM   #4
Bite the bullet, get the mamba max for the crawlermaster. I've been playing with it for some time, and I've decided it's a 14.4 volt or bust motor, but I've recently scaled the packs down from subC cells to 2/3A cells. Honest, the crawlermaster with a MM on 14.4 volts is a can't miss combo unless you have a mallet for a throttle finger.
cotharyus is offline   Reply With Quote
Old 08-24-2007, 10:57 AM   #5
thanks for the replies guys i appreciate it. Ok so best combo would be the MM. What if i went with the revolver think itd be a better combo for the M25, or should i just get maxxed and be done with it?. By the way this truck is too cool, played w/ it for hours last nite, and only broke the rear triangle link. Way to much fun:-P
