Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: WK diff compatibility?
Old 08-27-2007, 09:14 PM   #1
Default WK diff compatibility?
Does anyone know if the Wheely King diff components (IE spiders) will fit into the stock AX10 axles?
mrwonderful is offline   Reply With Quote
Old 08-28-2007, 12:40 AM   #2
Axial's Avatar
While the axles are very similar they are not an exact match to the wheely king axles. With that being said the spider gears are one part that will work, you may have to play with the shimming of the gears but they will work.
Thanks,
Axial
Axial is offline   Reply With Quote
Old 09-15-2007, 04:20 PM   #3
is this so that you can get the differential action? i would be wanting this for when i run it in my street. or Axial, do you think it wont be a problem running on tarmac with locked axles?
landy-ross is offline   Reply With Quote
Old 09-16-2007, 09:58 AM   #4
its a rock crawler not an airplane!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
BEAU is offline   Reply With Quote
Old 09-16-2007, 11:19 AM   #5
Not just limited to rock crawling though-i just use mine as a backyard bomber & crawling over STUFF-not rocks!
RiderZ is offline   Reply With Quote
Old 09-16-2007, 11:41 AM   #6
mine will be used as a basher that has great articulation, that can crawl over things if it wants. a mini Uk spec winch challenge vehicle is what i am aiming for. and i want the differential action so i can swop the diffs so i can run it in my street.
so does anyone know if they are a direct fit?
Old 09-16-2007, 11:48 AM   #7
I think Beau was referring to the fact that he used the term "tarmac"
Mad Scientist is offline   Reply With Quote
Old 09-16-2007, 06:22 PM   #8
Wk spider gears fit and work perfectly, for anyone who's interested.
Old 09-17-2007, 03:25 AM   #9
ahh perfect! thanks mrwonderful.
