09-03-2007, 10:49 AM | #1 |
Quarry Creeper Join Date: Aug 2005 Location: Tucson
| Anyone using the Crawlmaster
The crawlmaster bolts up just fine to the tranny of the AX-10 but, when you use the stock 14tpinion and 87t spur gears, the motor sits to close to the tranny. This would be fine if it was a brushed motor, but seeing as it is a brushless outrunner, when the motor turns, it rubs against the tranny case. This is a big no-no!!! Will a bigger spur gear like a 93t solve the problem? Also, should I change to a bigger pinion gear as well. Any info would be awesome on what others are doing to solve this problem. THANKS |
09-03-2007, 10:57 AM | #2 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
i am running a revolver and a 12T with the stock spur. didnt know the CM was that much bigger
09-03-2007, 11:08 AM | #3 |
Quarry Creeper Join Date: Nov 2004 Location: Mid TN
I had the same problem with the Scorpion 3014 - I just dremeled a little off the top screw sleve on the tranny and it was fine.
09-03-2007, 07:34 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
My son is dropping driveshafts with a 55 turn lathe motor. A crawlmaster would kill it! |
09-10-2007, 03:15 PM | #5 |
Pebble Pounder Join Date: Aug 2006 Location: in "Joisey"
I thought I read in the instructions that there was a "optional" outrunner plate you can buy? Would that solve the problem?? I was thinking of getting the Mamba Crawlmaster also... :-(
09-10-2007, 05:01 PM | #6 |
Doesn't matter - I wouldn't pay for a new plate with 5 seconds with a dremel fixes it.
09-10-2007, 05:35 PM | #7 |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
the CrawlMaster has a standard 1" bolt pattern like any 540 can... the optional plate is for the smaller bolt patten brushless motors... the CM is a monster in size and performance... I'm using a 14t - 90t combo with no rubbing.... you will get some rubbing on the skid plate which is easy to fix with #4 washers between the tranny and skid.... no grinding needed |
09-10-2007, 06:41 PM | #8 | |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
I think revolver might be choice for brushless motor over I was going for brush motor Integy 55T How do you like the relovler? I'm planning to use with mamba max. what is your battery setup? 6 cell or 8cell .....2500,3000? | |
