Thread: New Electronics Tray
Old 09-20-2007, 05:39 AM   #21
Hey EeePee,
Where'd you get the nice looking metal tray? This is a great idea
cwkoehler
cwkoehler is offline   Reply With Quote
Old 09-20-2007, 01:54 PM   #22
MODERATOR™
EeePee's Avatar
Originally Posted by EeePee View Post
I then drilled three holes in a piece of plastic using the original aluminum plate as a template.
It's from a toolbox. Used to make seperate compartments in a drawer. Any piece of plastic with some sort of rigidity would work. Mine's somewhat flexible.
EeePee is offline   Reply With Quote
Old 09-20-2007, 02:40 PM   #23
Default mounting
just built one of these..complete newbie.. from what I'm seeing the tray you built is attached in the back only? dson't have my Scorpion next to me so I'm trying to visualize.
Hatman is offline   Reply With Quote
Old 09-20-2007, 09:18 PM   #24
MODERATOR™
EeePee's Avatar
That's right.
The screw keeps it attached, and the two posts keep it centered.
Old 09-21-2007, 02:13 AM   #25
this is a great idea! but you also have to let them know to shave the plastic mount to the middle line, so the drive shaft can move freely
BEAU is offline   Reply With Quote
Old 09-21-2007, 03:04 PM   #26
MODERATOR™
EeePee's Avatar
I don't have clearance issues.
Thanks.
Old 09-22-2007, 10:44 PM   #27
cant believe I didnt see this thread earlier, awesome mod
rocresq is offline   Reply With Quote
Old 09-22-2007, 10:48 PM   #28
Now Im thinking you could do this in back for a dig. sheeeez to many projects
Old 09-24-2007, 12:09 PM   #29
Default Works great
Thanks - awesome idea. I completed the mod to my AX10 a couple days ago and I love it. Far superior to mounting the electronics to the underside of the stock battery plate.
Taffey is offline   Reply With Quote
Old 12-28-2007, 02:37 PM   #30
couldn't you just cut the aluninum stock battery plate a certin leingth and use instead of plastic>?
Dirby
Dirby is offline   Reply With Quote
Old 12-28-2007, 02:44 PM   #31
MODERATOR™
EeePee's Avatar
No way. Cut something? That's crazy talk!
Old 01-02-2008, 03:52 PM   #32
Ooober clean Ax10!
grover is offline   Reply With Quote
Old 01-02-2008, 04:04 PM   #33
MODERATOR™
EeePee's Avatar
Thanks Chad.
It's a great truck. I bought the servo and battery mount from Axial for the front axle, and went to a small Thunder Power 1320 Lipo.
I like it even better.
AX10 Optional Battery/Servo Plate
Old 05-15-2008, 01:57 PM   #34
I've just built my AX10, my first ever r/c car btw, and after reading this thread I started to look around for bits and bobs to mount my electronics to also.
I have an Airtronics MX-3 setup, and the receiver fits perfectly in the 4xAA holder that comes with the set. So I repositioned the plastic crossmember as mentioned above, down to the upper-link position, screwed through the batter holder, then popped the receiver right into - doesn't even need velcro, and it's kinda protected too.
I also dropped the front plastic cross-member to the same upper-link position, and screwed the spare servo plate to it, and attached my Novak Rooster to it with foam-tape. Then I bit the bullet and split my new 4200mAh stick up, and strapped the 6 cells around the front axle / servo area. It's all made the world of difference. Would I still need lead weights in my wheels, considering I have 6 large cells over the front axle? Would that help too, or just add unneccessary weight? Sorry for all the questions, btw...
Fat-Alfie is offline   Reply With Quote
Old 02-08-2010, 07:12 PM   #35
Man, that's why I love this site. I like that way better than the lexan tray attached to the upper links. I am going to change mine.
g_green is offline   Reply With Quote
