10-10-2007, 10:20 PM | #21 |
Moderator Join Date: Apr 2004 Location: In my head
| I don't have a better pic, but look at the last pic in post #11. I just used the stock Axial mount as a templet and redrilled the CG-1 mounts. Just don't do it backward like I did the first time, that why I have 3 extra holes in my link mounts!
10-16-2007, 07:46 PM | #22 |
Thanks for the heads up RX, I am in the market for a new comp rig for 08. After seeing the CG-1 this weekend in Disney, I have narrowed the field significantly. Are those 110mm shocks? |
10-16-2007, 11:43 PM | #23 |
I think so. They are longer than the big bores but alot shorter than the stock Scorpion shocks. I need to work on this rig some more. Needs a cool body any one got any suggestions. No bug body for this one.
10-17-2007, 02:04 PM | #24 |
Quarry Creeper Join Date: Nov 2006 Location: San Jose
Have you changed the shock position yet? I tried it your way and the shocks would compress before I could get any good articulation. I made some brackets to move the shocks to the top of the axles to try to keep the same geometry as the TLT axles. It works great. I actually like the Axial axles better! |
10-17-2007, 07:37 PM | #25 |
[QUOTE=killjoyken;886626]Have you changed the shock position yet? I tried it your way and the shocks would compress before I could get any good articulation. I made some brackets to move the shocks to the top of the axles to try to keep the same geometry as the TLT axles. It works great. I actually like the Axial axles better! QUOTE] Did you mean to say they bind? That what mine did. No I haven't messed with it any more. I'm going to try to space them out at the top of the chassis more. If that don't work I may try your set up, it looks good. |
10-17-2007, 07:45 PM | #26 |
I'm still waiting to hear from Gatekeeper on mine, can't wait **DROOL** , I'll be keeping an eye on this thread. |
10-17-2007, 08:35 PM | #27 |
Well since your getting one, I'll get to work so I can get it dailed in for you. You know your going to have to come to a SERCRC comp now.
10-17-2007, 08:41 PM | #28 |
10-18-2007, 06:17 AM | #29 |
Newbie Join Date: Aug 2007 Location: Richmond
GC-1 rules! |
11-05-2007, 02:18 PM | #30 |
Do you have any issue with the links hitting the axle mount plate limiting your articulation? Thinking about putting some small spacers under the TLT stays to lift the links aways from the mount
11-05-2007, 04:25 PM | #31 |
I've noticed on my TLT GC-1 that they hit a little, but it is at the same time the shock bottoms out. So it doesn't affect the truck. I've been really busy lately so I haven't mess with the AX-10 truck. I would probably trim the plate some before I spaced the mount up. I don't want to mess up the link geometery. The little bit you would space it might not make a difference anyway. I would get Austin's opinion.
11-06-2007, 05:10 AM | #32 |
When my links hit, I still have about 3/8" or so before shock is fully compressed. I am using Evader ST shocks. I will try shaving the mount down a little to compensate.
11-06-2007, 05:36 PM | #33 |
Newbie Join Date: Sep 2006 Location: Gadsden
how long are the shocks? are they 4" ?
11-07-2007, 05:36 AM | #34 |
110mm eye to eye extended
11-07-2007, 05:53 AM | #35 |
RCC Addict Join Date: Feb 2007 Location: LRC
11-09-2007, 06:15 PM | #36 |
Here are the pics of my GC-1 AX10. I just installed an R2D. That was a chore in this chassis, not a direct fit. I am sitting at 12 1/2 right now. GateKeeper got them decals yet? I think my crawler is worthy now....... |
12-31-2007, 11:29 PM | #37 |
RCC Addict Join Date: May 2006 Location: Roseville
Those Revo links, are they 102mm eye-to-eye? I am going to make my own links (first for me) and I want to try to get them the right lengths from the get-go.
01-01-2008, 06:48 AM | #38 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Are you done with this POS yet? Or do I need to come set it up for you. |
01-01-2008, 11:37 AM | #39 |
Trikster, they are the 102mm revo links. Personally I'd wait until you have everything befoer you make them. Or build in a little adjustability. Rockcrawler, YES please come over and finish all my projects! ATTN: Rockcrawler in have a podium finish at Nationals in '08. |
01-01-2008, 12:09 PM | #40 |
