09-27-2007, 11:20 PM | #1 |
Moderator Join Date: Apr 2004 Location: In my head
| RX's 08' Comp rig finally....
Haven't got much done on this truck yet. Still need to decied which shocks to use. Hopefully I can get it to crawl as good as the one in the background.
09-28-2007, 07:02 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: *
Sweet RX...Is the wheelbase the same as the TLT???And are those the same links??? Now I know your secret to success...I smoked those for years and they always made me feel good, but now since I quit I hate everybody... |
09-28-2007, 09:47 AM | #3 |
Yes the links are the same as my TLT GC-1 revo pushrods. The wheelbase should end up around 12.5, haven't measured it yet. But rcxj ran a simular set-up at nationals.
09-28-2007, 11:19 AM | #4 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
having the top links parallel and the lower links triangled or is having it the other way around better. I thought that having both upper and lower triangled with the points opposite of eachother. Example Upper< lower> |
09-28-2007, 12:09 PM | #5 |
The GC-1 seems to work well with the upper parallel to the ground and to each other. and the lower links triangled. No axle swing and VERY little torque twist.
09-28-2007, 04:09 PM | #6 |
RCC Addict Join Date: Dec 2004 Location: Behind the wheel of an Axial R/C
Nice Joey. I'll keep an eye on this one. I got a couple of guyz here that want to do this to their GC1's.
09-29-2007, 09:10 PM | #7 |
Rock Crawler Join Date: May 2006 Location: Georgia
Hey Joey I have had good success using the stock shocks on my wifes AX-10. As long as you dont over fill them they will work fine. But to much oil and it will blow the cap off. You may want to limit them though, they are a bit long. Im also using some AE green and silver springs. http://www2.towerhobbies.com/cgi-bin...?&I=LXBVG0&P=7 |
09-29-2007, 11:14 PM | #8 |
So I should probably let some out... What not even too the rim?
09-30-2007, 05:24 AM | #9 |
Yeah I filled ours to just below the rim. You will know if they have to much. They will be very stiff. |
09-30-2007, 05:47 AM | #10 |
I wanna be Dave Join Date: Feb 2004 Location: on a Big Rock
| I dub thee ....................GX11 |
10-04-2007, 06:27 PM | #11 |
Haven't gotten a lot more done but here are some newer pics.
10-04-2007, 08:23 PM | #12 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
what shocks are them.
10-04-2007, 10:01 PM | #13 |
Pebble Pounder Join Date: Jul 2007 Location: Shorewood
sweet. il like that your using 1 addition for another nice rig
10-04-2007, 10:01 PM | #14 |
Rock Stacker Join Date: Sep 2007 Location: SAN JOSE
fill up the shocks with the shafts compressed. That way you won't have problems when the shaft compresses and displaces the shock oil. Just my .02.
10-04-2007, 10:42 PM | #15 |
Pebble Pounder Join Date: Jul 2007 Location: Okinawa, JP
| shock mounts
how did you connect your shocks to the axels? it looks like the shocks are mounted on the outside of the mounts or something??
10-05-2007, 04:23 AM | #16 |
I got the shocks from JP Customs, they are shorter than the stock AX-10 shocks and longer than Traxxas Big Bores. The lower links are mounted to the inside and the shocks are mounted to the outside of the stock link/shock mount closest to the wheels.
10-05-2007, 08:34 AM | #17 |
Woke up early this morning and finished it up. Drives alot like my TLT axled GC-1. |
10-09-2007, 11:33 PM | #18 |
Quarry Creeper Join Date: Nov 2006 Location: San Jose
Now when you say, "drives a lot like", do you mean the same, a little better or a little worse? I'm in the process of swapping my TLT axles for AX10 axles on my GC-1 and wanted to get a pro's opinion. I'm hoping the AX10 axles will prove tougher than the TLTs. |
10-10-2007, 04:28 PM | #19 |
do you have a better pic on mountting the top links onto these axles w/ the bracketed that come with chassis. thanks |
10-10-2007, 10:17 PM | #20 | |
It's a little worse, but that is only because of the shocks. I need to mess with their mounting on the chassis, right now they are binding a little. Once I get the shocks worked out it should be better than the TLT axles (more clearance under the axle). | |
