10-11-2007, 12:00 PM | #41 |
Pebble Pounder Join Date: Nov 2006 Location: 303
10-11-2007, 04:19 PM | #42 |
Newbie Join Date: Oct 2007 Location: In a false state of reality
yeah trash that thing, I dont care |
10-11-2007, 04:45 PM | #43 |
RCC Addict Join Date: Sep 2006 Location: Redlands
Love it..
10-12-2007, 01:50 AM | #44 | |
Pebble Pounder Join Date: Aug 2007 Location: St. Albert - Canada
After using the ¾” fuel tubing in the shocks, I get the same “just under 3” of belly clearance with a stock AX-10 on Lizards. Now it “climes” and “hills” like a spider. I have not added weight and Betty is mounted sky-high with a Blower! Thank you again Mr. Bender. | |
10-12-2007, 05:47 AM | #45 |
Newbie Join Date: Oct 2006 Location: australia
I have one question have you ran it on rocks yet ? Please tell if so how she went . This is a very nice build .
10-12-2007, 07:47 AM | #46 | ||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Thanks guys. | ||
10-13-2007, 05:04 PM | #47 |
I managed to get a little testing in today. It works a lot better then I ever thought a super lightweight 12" wheelbase rig could. I was able to make almost every line at Red Rocks that my 2.2 comp rig can do. Here's a few pics on the rocks. I shot a little video too, I'll try to get it posted tonight. |
10-13-2007, 05:17 PM | #48 |
Looks extremely capable… How much weight did you end up adding?
10-13-2007, 05:21 PM | #49 |
| I'm not running any extra weight at all yet, I wanted to try this set-up first. I'm guessing it weighs about 4 pounds RTR right now. Next I will add some weight to the wheels, probably about 3-4 ozs in front and about half that in the rear. Then will see how it performs. |
10-13-2007, 07:16 PM | #50 |
So how was the Black/25 with those packs? I just got done building some for mine+I am running a Black/25 combo, so I am curious. Also I am using my Spektrum DX-3, did you ever have issues with your Spektrum shutting down running the new packs, with the 25? I have not run mine yet exept with a 3cell lipo on the carpet but with this rig I didn't think it was necessary.
10-13-2007, 07:31 PM | #51 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
666: If its a lower voltage type shut down, I used to get them with my Brushless 4wd buggy and high power servo. I assume it could be the same, decent draw might cause the spektrum to loop out. Spektrum sells a capacitor I ended up having to use. Stores the juice for when amp draw is high and prevents the "shut down" due to power draw. They are cheap too...might be worth a shot.
10-13-2007, 07:41 PM | #52 |
I know all about that, been there done that, the fix is to get the drain away from the receiver via regulator or receiver pack. I was asking BENDER if he has had the issue with the weak BEC on the Mamba 25. In my experience the capacitor thing does nothing. |
10-13-2007, 08:35 PM | #53 | |
10-13-2007, 11:11 PM | #54 |
Video is up. Video of SW3 with AX10 axles and tranny........ |
10-13-2007, 11:35 PM | #55 |
Quarry Creeper Join Date: Aug 2006 Location: Monroe NC
Great video Brad! I am starting to contemplate changing the direction for my SW3. |
10-14-2007, 07:53 AM | #56 |
Pebble Pounder Join Date: Sep 2007 Location: Not where i should be
Looks great in the video I'm keen to get my hands on a sw3. Could you supply all that is needed to convert a box stock AX10?
10-14-2007, 10:09 AM | #57 | |
Parts from the AX10 kit you can use....... Axles Tranny Upper links Chassis standoffs Shocks Steering tie rod and drag link Body posts Wheels Tires Driveshafts Metal yokes on tranny and axles Rod ends Assorted M3 hardware I think that's pretty much it. | |
10-15-2007, 08:41 AM | #58 |
Quarry Creeper Join Date: Oct 2006 Location: wollongong, NSW, Australia
| Awesome!!!
The performance of this truck is amazing!!! Sorry if I missed it, but what is the GC? Shane |
10-15-2007, 10:15 AM | #59 | |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Rockmuncher > Quote:
10-15-2007, 08:03 PM | #60 | |
I finally got a chance to weigh this rig today, weighed in at just a tick over 3.6 pounds. I swapped out to my Axial beadlocks and added some weight to the wheels, and it still only weighs a hair over 4.3 pounds. I am going to try and give it another test run soon. I did notice that I broke the upper link mount on the front axle too. It still works, but it is cracked. | |
