10-15-2007, 08:22 PM | #61 | |
My rear upper link mount is broke/cracked too, and I have not even crawled rocks yet..... | |
10-15-2007, 09:08 PM | #62 |
I ran mine cracked for a while, and with the washer there it actually never completely let go.
10-15-2007, 09:15 PM | #63 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
| Yeah, I threw the washers on when I built it up too. I don't think it'll be a big deal for now. I threw some fuel line in there too, to remove the little bit of slop the rod end had.
10-16-2007, 02:11 PM | #64 |
Quarry Creeper Join Date: Sep 2007 Location: Looking for rock piles
how can i get one and how much?
10-16-2007, 07:53 PM | #65 |
| If you're looking for the chassis, here's a link to my vendors thread. Bender Customs SW3 Chassis........... |
10-17-2007, 10:43 AM | #66 |
Newbie Join Date: Oct 2007 Location: In a false state of reality
The rig looks great, the video was cool, the only thing missing were the hot chicks. Maybe next time.
10-17-2007, 09:37 PM | #67 |
I wanna be Dave Join Date: Jun 2004 Location: Whales
I dig the rig I too have been playing with a lighter rig and it seems to work really well. |
10-17-2007, 11:07 PM | #68 | |
Thanks man. I was surprised how good it worked at 3.6 pounds. Even with foams and shocks that were too stiff, it did 90% of the lines I can do with my SW3 TLT. | |
10-17-2007, 11:35 PM | #69 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Where have I been? Damn call me next time you go out there with this feather weight. |
10-18-2007, 06:18 AM | #70 |
Newbie Join Date: Aug 2007 Location: Richmond
Nice looking rig!
10-18-2007, 09:38 AM | #71 | |
I think you mentioned that you noticed how the Losi tires performed better with a light rig and I think that's the key. Pinch's and my rigs are below 4 lbs and there running better than ever. So if your making this rig for someone else, are there plans to run one yourself? | |
10-18-2007, 10:45 AM | #72 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
I ran my SW2 super light for over a year and had OK luck with it but I think it was due to the Moabs. When the Losi's came out Brad said they would be sweet for my rig and it looks like he was right! Too bad I am building an SW3 for the winter series and it is already heavier than my other rig and I don't even have a transmission mounted up yet! Brad, I may have to hit you up for some lightening of my MSD wheels. I have a new part you may be interested in to... PM me for more info! |
10-18-2007, 03:10 PM | #73 | ||
Sending you a PM now. | ||
10-19-2007, 11:42 AM | #74 |
I added a little weight to the wheels and it's performing a lot better now. Just adding a few ounces made a huge difference. I also countersunk the tranny mounting holes and mounted the tranny with flathead screws, so the bottom is nice and smooth again. Last edited by BENDER; 10-19-2007 at 11:58 PM. |
10-21-2007, 12:15 AM | #75 |
RCCRAWLER TEAM DRIVER Join Date: Jun 2005 Location: Voiding warranties
After driving this rig today I still can not belive how it side hills I have a lot of TLT stuff that might be going away to make room for one of these. Awasome rig Brad you got the set up perfact |
10-21-2007, 08:31 AM | #76 |
| Thanks man, I'm really happy with how it turned out. I'm also surprised at the performance of it for weighing less then 4.5 pounds.
10-21-2007, 10:02 AM | #77 |
Newbie Join Date: Feb 2006 Location: RENO
Looks like a great combo, I have been thinking about getting these axles and tranny for the strength and clearance of the axles, also I like the idea of a really light rig...keep up the nice work!
10-21-2007, 10:39 PM | #78 |
Newbie Join Date: Oct 2006 Location: australia
So Bender which do you like the best tlt based comp rig or the ax-10 version .
10-21-2007, 11:46 PM | #79 |
| I love my SW3 TLT, but this SW3 AX10 is turning out to be a very capable rig, with very little tweaking. We had a few 2.2's out at a local crawl spot this weekend, and the AX10 SW3 did almost every obstacle my TLT based comp rig could with a shorter wheelbase. It's also a little lighter set-up then my 2.2 comp rig, which should be easier on parts. I may build one up for myself at some point. I'm sure with a little more testing it could be as capable as my rig, if not more. |
10-27-2007, 09:36 AM | #80 |
Turns out I had the wrong turnbuckles linked to the first post, I just edited it for the correct part number. You want Traxxas part #5538 (61mm Jato turnbuckles), not #5539 (58mm Jato turnbuckles) to use as lower links with the stock AX10 upper links. I also added the upper link chassis spacers for the stock chassis to the upper 3 link mounts, at the axle. Like the CKRC tech article on the front page. You can see the extra green spacer on the upper 3 link in the 7th pic. I had to use a longer M3 screw, but it stretches the wheelbase out to 12 1/2", instead of the shorter 12" wheelbase I started with. |
