10-28-2007, 05:59 AM | #81 |
Pebble Pounder Join Date: Nov 2006 Location: scarborough CANADA
Brad. Which white buggy springs did you use for this build? is it the front springs or the rear losi ones. i am just curious because i went to buy some yesterday and there were two rates. another top notch build as always. thanks again. |
10-28-2007, 06:09 AM | #82 |
Rock Stacker Join Date: Jul 2007 Location: colorado
he runs the 1.8's i believe
10-28-2007, 06:49 AM | #83 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
| I do run the 1.8's, they are part number LOSA5147. |
11-04-2007, 06:11 PM | #84 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
Mine is going together right now....can't wait......just need more hardware!! |
11-04-2007, 08:53 PM | #85 |
11-05-2007, 06:31 AM | #86 |
Thanks Brad.....I'll do that BTW ,,,looks like the second game had the outcome you desired Good one to watch...........
11-10-2007, 08:16 PM | #87 |
Took the ax-10 / SW3 out, and am very impressed. Now I have a rig that does what I think it should........:-P Ax-10'ers give the build a try, you'll be HAPPY |
11-10-2007, 09:06 PM | #88 | |
Thanks cato, your rig was working awesome today. | |
11-12-2007, 08:13 PM | #89 |
I wanna be Dave Join Date: Oct 2007 Location: 801
WOW! I cant stop looking at this build. I have an axe and new to the sport and i am looking at getting some better perfomance. Besides the weight factor what else could the SW3 offer me compared to stock. I am just below 3" now with my big bores and losi whites (front) and Losi red (rear.) I love my setup but just cant break over ledges very well. Would the SW3 break over easier at the same chassis hight as what i am at now? This may be a stupid newbie question but i would have to think that being lighter and thinner than the stock chassis would help with breaking over things, but then again 3 inches of clearance is 3 inches of clearance.
11-12-2007, 09:52 PM | #90 | |
Hope that helps. | |
11-13-2007, 11:39 AM | #91 |
Thanks bender, i will order one asap. I have to be honest my two buddies bought an axe and have copied every upgrade that i have done, springs, revolver black brushless motors, mamba max, cutting the foams the same, and now they are giving me a good run for my money so i need that extra bit of advantage. Plus the way things are going if i get one, you will soon sell two additional ones to my two buddies, which doesnt hurt your business. Maybe if you have a second, and since you have the experience playing with the sw3 axial you can give me some pointers as far as what link holes and setup to use so that the anti-squatting and geometry is set right. my set up is tmaxx 4" big bores with 60 wt all the way around losi whites in the front and Reds in the rear. I have proline moab M3 and claws on the way this week. Right now my rig really likes to pull the front right off the ground and wont come back down. on the ground though i have zero torque twist. I am thinking of doing your 10wt in the front and 30 wt rear like you set this one up. Again i am new at this sport so I really appreciate your time and explaining things.
11-13-2007, 11:48 AM | #92 | |
I found that setting the SW3 AX10 up with the upper links mounted in the middle hole to start worked good. That's where I ended up before I gave this rig to the owner. Running stiffer oil and springs in the rear shocks will help fight the torque twist, link set-up can play a big role too. I would lighten up your shock oil set-up in the front, it'll help the front axle flow with the terrain better. The front of my 2.2 comp rig will sag a little under it's own weight, while sitting on level ground. Let me know if you have any more questions on set-up. | |
11-13-2007, 12:06 PM | #93 |
Great Ill keep you posted when I order my chassis and get some pictures up soon. Thanks Again! |
11-13-2007, 05:38 PM | #94 |
Pebble Pounder Join Date: Sep 2007 Location: Not where i should be
Could anyone give me the measurement for the lower links from center of the rod end pivots. Thanks |
11-14-2007, 12:08 AM | #95 |
11-14-2007, 09:26 AM | #96 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
brad, did you happen to notice/check the servo mounting plate on these? i was just wondering if a set of your servoplate/upper link mounts would bolt on to a set of these axles? the stock servo plate looks almost identical to a stock TLT servo plate...
11-14-2007, 09:44 AM | #97 |
| The hole patterns are different between the TLT and the AX10 axles. But, there is enough room to add the AX10 mounting points to my TLT link mounts, without any holes hitting each other. |
11-14-2007, 10:18 AM | #98 |
| cool, those link mounts are just so well made, i find it hard to give them up.... |
11-14-2007, 07:00 PM | #99 |
wheelbase 12.5 inch. Lower links 97mm eye to eye +-............Using Traxxas 61mm links.......cheap and strong also added 6mm of spacers on upper rig is hooked-up |
11-14-2007, 07:31 PM | #100 |
