10-24-2007, 09:53 PM | #1 |
Quarry Creeper Join Date: Apr 2007 Location: Kapahulu Safeway
| RCP Ax-10 Knuckles and MSD Beadlocks
Just a heads up. The inner beadlock ring on the MSD beadlocks makes contact with the RCP ax-10 knuckles. It's not that bad. I'm just going to take a little off the rings.
10-24-2007, 10:06 PM | #2 | |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
I think it would be easier to shave a little of the knuckle? No? Not sure I dont have any MSD's. How close is it anyway? John | |
10-25-2007, 02:10 AM | #3 |
They touch. I don't want to weaken the knuckle, but it would be easier to take some metal off the knuckle.
10-25-2007, 06:43 AM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Mine don't touch on the Aluminum new MSD's. Close though. I haven't drilled out the center hole for the aluminum hexes, so currently I'm using the "spare" plastic ones with that "tit" cut off. I left the small inner ring so I do have 1 step after the hex, but so does the Axial Aluminum ones. I did talk to RCP about my knuckles front edge appeared to be hand sanded/filed and I was informed it was for the stock Axial wheels and rings, which makes sense since the stock wheels and rings have more offset. Pics of my scenario as it stands. |
10-25-2007, 02:49 PM | #5 |
I'm using hexes that allow the wheel to sit flush against them.
10-25-2007, 03:07 PM | #6 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
I'd shave the knuckle more, I doubt it will weaken it much. If it does, and you bend them, we will replace them. We have made a change in that area of the knuckle. We didn't have any MSD wheels to check for clearance.
10-25-2007, 03:43 PM | #7 |
From what I can tell, all you'd need to do is chamfer that corner on the inside edge of the rings.
10-26-2007, 02:06 PM | #8 |
| I'll give that a try. Thanks for standing by your products. One of my knuckles at the arm area has been ground down quite a bit to make room for the stock wheel clearance issue (not by me), significantly more than the other one. If that one snaps at that point, will it also be replaced?
10-26-2007, 02:11 PM | #9 |
Rock Stacker Join Date: Sep 2007 Location: seattle
10-26-2007, 02:28 PM | #10 |
The grinding when they are new was something RCP stepped up and did to get these out quickly. I talked to RCP about it and they said the stock wheels and the Knuckles had a small clearance issue and instead of sending them back and having us all wait they modded them in house. I'm grateful they did. Sure it looks odd but works well (I have tried them now with the stock wheels too). I was also told if I had a problem with them let them know. I can say RCP is a great company to deal with who cares enough to check parts before shipping. I know for a fact they'll be seeing a good deal more of my business. |
10-26-2007, 02:47 PM | #11 |
| Absolutely! Thanks we appreciate the kind words. |
10-26-2007, 04:12 PM | #12 |
11-30-2007, 09:24 AM | #13 |
Newbie Join Date: Nov 2007 Location: Germany
Hey have you noticed if the clockable C help any and what knuckles did you use
11-30-2007, 08:59 PM | #14 |
11-30-2007, 09:17 PM | #15 |
I guess I mean is it worth getting the clockable C's what do they do? Sorry just ordered the AX-10 w/ stage 2 kit so I am still wet behind the ears when it comes to the crawling game
11-30-2007, 11:44 PM | #16 |
Pebble Pounder Join Date: Jan 2005 Location: canada
I jst got my knuckles from RCP for the AX10 for my 1.9 scale build. The knucles will not clear any of my 1.9 wheels....i was hoping to use them for the build but I really dont want to have to modify them to fit .......so I have to use stock for now///james
