![]() | #21 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Gary, the RCP parts are real nice. I definately recommend the SS Axle and Adaptors together, ran at the comp and a bit before with the stockers and the stock axle stub on only 1 bearing isn't ideal, got a wee bit of bind/grinding. I know I couldn't be happier with the RCP parts. I'm still iffy on the shocks yet... |
![]() | #22 |
Newbie Join Date: Aug 2007 Location: virginia
nice crawler, i like the bent links ![]() |
![]() | #23 |
Rock Crawler Join Date: Jan 2006 Location: commerce twp.
the stage 2 kits works pretty good but i think i can make it a little better. i seen rubbanecks build and seen my next upgrade. i have a bender sw3 on order should be here any day now. i'm going to set it up just like rubbanecks i hope he doesn't mind but i really like that set up, i will get some pics up when it arrives. thats all for now. ![]() |
![]() | #24 |
Quarry Creeper ![]() Join Date: Dec 2007 Location: At the Gates
put the rubber spacer under the piston and used 3/8 piece of fuel tubing on the out side of the shock to limit flex. [/quote] why would you want to limit flex ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() | #25 |
Pebble Pounder Join Date: Nov 2007 Location: Bay Area
just out of curiosity does anyone run the ckrc aluminum knuckles? http://www.ckrccrawlers.com/shop/ind...roducts_id=272 if so how are they? |
![]() | #26 |
i really don't like a real lot of flex, it just gives you more axle steer.
