11-19-2007, 05:42 AM | #1 |
Newbie Join Date: Jun 2007 Location: buffalo
| who makes aluminum shocks for ax10
lie the title says who makes aluminum shock bodies or what shocks from other cars work. thanx
11-19-2007, 06:02 AM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: tx
Axial makes the shock bodies but you still have to use the plastic caps. You could go with a set of Big Bores in alum.
11-19-2007, 06:12 AM | #3 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
since most people are putting 1/2 to 3/4 inch spacers inside the shock to lower the ride-height , Losi rear off-road shocks work well also. |
11-19-2007, 07:08 AM | #4 |
Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
Integy has aluminum shocks..4 colors..2 different length rod ends so you can adjust free height...also comes with droop/internal springs I canceled my order for the axials...$60 for 4 bodies versus $70 for a set |
11-19-2007, 07:11 AM | #5 |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
I had choice to Integy with peggy back shocks but I went to Traxxas Big Bore at local shop for 75bucks... for eight of them..
11-19-2007, 07:39 AM | #6 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
| I have the Integy internal spring shocks I love them they really work awsome. And you can run droop like I do or standard with springs on the outside
11-19-2007, 07:42 AM | #7 |
I also got them in green. GO GREEN they look kool |
11-19-2007, 08:48 AM | #8 |
Rock Stacker Join Date: Aug 2007 Location: Weatherford
I Am Using The Big Bores, But Using The Stock Ax-10 Shafts..witht He Red Big Bore Springs...man..it Sets Perfect! After I Get Everything Blasted And Powder Coated, I Will Post Pics.. |
11-19-2007, 08:56 AM | #9 |
| Big bores are a good shock for the ax-10 but I'm running a gopher chassis with a droop setup and the integt shocks work great for that application
11-19-2007, 09:24 AM | #10 |
Rock Stacker Join Date: Jun 2007 Location: Calgary
Im running duratrax evader shocks upside down with ax10 shock shafts and soft spring up front. Lowered my ride height a bit, offers a lot of tunnig options and the shocks are very smooth compared to stock shocks.
11-19-2007, 11:05 AM | #11 |
Newbie Join Date: Nov 2007 Location: Seattle
Integy MSR10 shocks are pretty cool looking and are non-piggy back but I've yet to see someone run them. I'm currently using Traxxas Big Bore shocks (4962) but the top caps had to be modified. I used a dremel to grind the upper cap mounting hoop down to the cap, then drilled a 3/32 hole through it, put a screw through the bottom of the cap into the same style of link that's on the bottom end, and replaced the diaphram. No leaks and works great. photo of modified Traxxas Big Bore shocks using their aluminum caps with link ends: Last edited by moonweed; 11-20-2007 at 01:29 PM. Reason: photo added |
11-19-2007, 01:31 PM | #12 |
Rock Stacker Join Date: Oct 2007 Location: Devon, UK
| Team Blue Star make some nice 100mm big bores.
11-19-2007, 05:14 PM | #13 |
thanks for all the replies, how much are the axial shock bodies? And where can I get alu shock caps to go with it?
11-19-2007, 09:10 PM | #14 |
I joined the Band! Join Date: Dec 2006 Location: RENO
we should have our new 120mm threaded bodied shocks for the axial by the end of the week.
11-19-2007, 09:27 PM | #15 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
11-19-2007, 10:06 PM | #16 |
I heard the traxxas big bores have aluminum caps which are interchangeable with the stock ax10 ones. Not for sure tho bro might want to verify with someone running the big bores.
11-19-2007, 10:10 PM | #17 |
I just had it front of me.. yes works.. I use traxxas big bore shock right now..:-P
11-20-2007, 11:33 AM | #18 | |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Chris | |
11-21-2007, 07:35 AM | #19 |
Newbie Join Date: Nov 2007 Location: SANTIAGO, CHILE
Hey i'm looking to replace my stock shock's with the traxxas big bores, but the question is .. Can i install it without any modification to the mounting spots and the shock itself? and how many cm or inches will lower my rig because as i can see the big bores are shorter than the stock shocks cheers!!! Gecko Last edited by gecko4x4; 11-21-2007 at 07:37 AM. |
11-21-2007, 08:20 AM | #20 | |
you will not problem dropping the shocks but you may need to move upper link to adjust. it will change the height of your rig. I can't remember what is the original height but mine is now 52mm high you can see my of changes http://gallery.mac.com/xtremeracingteam | |
