11-19-2007, 01:14 PM | #1 |
Newbie Join Date: Oct 2007 Location: UK
| Electronics Layout
Hi guys I now have all my Eletronics to put in my ax-10 although i am still waiting for the kit. Radio - Futaba 4YF-FM 4 Channel Radio Servo - Scanner RC SSV-9766MG Motor - LRP Truck Puller 2 ESC - Mtroniks Viper Battery - 2300 mAh NiCd Stick Pack I have been looking at the layout and am thinking of putting the motor battery under the tray mounting the reciver and reciver battery on the top of the tray and the esc on the back axle. Do you guys think this setup will be ok or do you have and other suggestions Thanks guys Peewee |
11-19-2007, 01:17 PM | #2 |
Pebble Pounder Join Date: Oct 2007 Location: InDePeNdEnCe
I have my battery on the plate, my esc on my back axle and my reciever under the battery plate. but i am trying to find a better set up.
11-19-2007, 01:33 PM | #3 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
biggest importance of where you mount just one oblect IMO iss he battery, You want it to be as far forward and as low as possible. BTW welcome to RCC!
11-19-2007, 01:39 PM | #4 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
buy yourself or build an $20.00 axle battery pack and mount you electronics's like this Last edited by yotachump; 11-19-2007 at 07:25 PM. |
11-19-2007, 01:42 PM | #5 |
Nor-CalRCRC Join Date: Dec 2006 Location: Monterey Peninsula
The lower you can make the center of gravity the better. Here is an example of one option. ESC - mounted to the rear upper links with a plastic plate zip-tied to the links. Battery - on the front axle either side of servo (you can buy battery packs like this pre-made now from vendors on this site) Receiver - servo taped to the side of the trans. Well I guess yotachump posted up at the same time - basically same set-up,,,, works great. Last edited by montereycrawler; 11-19-2007 at 01:44 PM. |
11-19-2007, 03:00 PM | #6 |
Rock Stacker Join Date: Sep 2007 Location: SAN JOSE
monterey, I don't know if you know this but carbon fiber affects radio reception. I don't know if it is affecting yours but I fly helicopters also and wrapping the antenna wire around carbon fiber is a no-no. I've seen a lot of glitches from wrapping the wire around CF. I really like the layout you have. |
11-19-2007, 03:39 PM | #7 |
My front axle plates are not installed yet but my battery will be on the front axle. Everything else is fairly clean and out of the way. Not too concerned about any heat build up between the Mamba Max and motor, we're crawling here not going fast so heat build up isn't an issue.
11-19-2007, 06:53 PM | #8 | |
Newbie Join Date: Nov 2007 Location: Japan
| My experience with carbon fiber Quote:
11-19-2007, 08:24 PM | #9 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
i prefer the method of battery over front, leave stock battery plate mount esc, reciever all underneath it . looks smooth and keeps things out of the way just a little .02 later
11-19-2007, 08:29 PM | #10 |
| lower the COG even more by moving everything as low as possible. i think the battery plate looks bad, but thats just my opinion.the way i did is really simple and look great |
11-19-2007, 08:54 PM | #11 |
yours is the best looking one i have seen that doesn't use the battery plate, i like how you kept inside the chassis versus some i have seen who put esc out back on the axle or reciver it's just not my style yours is clean for sure
11-20-2007, 10:21 AM | #12 | |
11-20-2007, 10:42 AM | #13 |
thanks or all the information guys i think the way to go is to get a set of saddle packs once i have got everything built Thanks Again Peewee |
11-20-2007, 12:55 PM | #14 |
Newbie Join Date: Nov 2007 Location: Seattle
Here's some photos of my setup with custom esc and reciever mounts in the tri-link areas and top plate permenantly removed. Also shown are Traxxas big bore shocks with uper caps modified to ball links. front end Goat esc mount: right side showing low center of gravity by lowering the esc/reciever: rear view of Nomadio Sensor reciever mount top view showing wireing: left side view of the Goat on/off switch mounted near the front body post: Last edited by moonweed; 11-20-2007 at 01:35 PM. |
11-20-2007, 05:46 PM | #15 |
