Thread: Diff locker stripped
Old 11-23-2007, 11:39 PM   #1
Default Diff locker stripped
As the title says, I stripped the rear diff locker today. Is anyone using any other locker? I saw a good looking wheely king locked ring and pinion set on RCP. Any suggestions? Thanks.
WKKILLER is offline   Reply With Quote
Old 11-24-2007, 12:13 AM   #2
The crawler store sells new lockers for it there $ 9.99 each order a new one
CRUZ CONTROL is offline   Reply With Quote
Old 11-24-2007, 12:17 AM   #3
A friend and I both ordered a set of these, hope they work well. Lots of people locally have been stripping the stocks and I would rather not be changing them out.
http://rc4wdstore.com/product_info.php?products_id=697
Anthony.L is offline   Reply With Quote
Old 11-24-2007, 05:43 AM   #4
Be careful. I was told wheely king lockers work.
THEY DONT. I purchased some WK lockers and discovered they do not work, HOWEVER you can buy WK dif buckets for 5$ and have bullet proof lockers. Maximizer makes some real nice lockers.
fishmasterdan is offline   Reply With Quote
Old 11-24-2007, 06:50 PM   #5
Fish,
Did you use the Maximizer locker in the AX10 diff bucket and it did not fit? I ordered the Maximizer locker, should I get the wheely king diff bucket or use the AX10? Thanks.
Old 12-01-2007, 12:56 PM   #6
I put the Maximizer Locker in the AX10 diff bucket. It only took a little bit of work with the Dremel to make it fit. The locker is sooooo muck nicer than the stock AX10 locker. A must upgrade for anyone with an AX10 IMO.
Old 12-05-2007, 06:20 PM   #7
I haven't stripped one yet. So hopefully this will prevent it from happening.
Drilled and tapped 4 holes for 4-40 set screws. Blue loctite and tightened them down on the shafts. And assembled. I'll see in the long run if it works.
dx-dow is offline   Reply With Quote
Old 12-05-2007, 06:59 PM   #8
[quote=dx-dow;950866]I haven't stripped one yet. So hopefully this will prevent it from happening.
Drilled and tapped 4 holes for 4-40 set screws. Blue loctite and tightened them down on the shafts. And assembled. I'll see in the long run it works.
Great Idea gona do that one tonight
shortcut is offline   Reply With Quote
Old 01-04-2008, 04:02 PM   #9
toy4crawlin's Avatar
Looks like Poor design if the shafts barely fit in locker
What Maximiser Locker Do you use for the AX
http://www.maximizerproducts.com/max...5d9954t$DF$E9$
toy4crawlin is offline   Reply With Quote
Old 01-04-2008, 04:08 PM   #10
Well Are they better?
do the axles fit in all the way?
it's still aluminum
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
