11-29-2007, 02:43 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Englewood, CO
| Axial springs vs Losi
Does anyone know how the white and yellow Axial springs compare to the Losi yellow and white. Are the colors a standard spring rate across all vendors? Or for example does each vendors yellow springs have a different spring rate? Also, are they different lengths? Thanks Last edited by Zardoz; 12-01-2007 at 01:44 PM. |
11-29-2007, 04:05 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Every manufactures springs are different the axial springs are 3.50 and the losi springs are 2.75. And also spring rates are different axials whites are 1.7 losi whites are 1.8same with the yellows losi 2.O axial 2.3
11-29-2007, 04:08 PM | #3 |
I personaly run the losi springs white fronts yellow rears |
12-01-2007, 01:43 PM | #4 |
Thats exactly the info I was looking for. Thank you very much. |
12-01-2007, 04:20 PM | #5 |
Also I got a great tip from grizzly4x4 you can use traxxas max shock cups they fit the springs better |
