Finally got one.. Well I finally got my Axe 10 today. I got it from CKRC Crawlers. Started the build today but will finish tomorow.. I'm running a integy 55t, with a 6cell battery and using a traxxas TQ-3 for a radio. For right now I have to use my wheely king stock speed speed controller till I can afford a quark 33 and run it with lipos."thumbsup" My question I have is it came with the gray springs, I had to put my biggest spacer on my shocks other wise the spring was just way to loose. Any suggestions or tips would be appreciated?"thumbsup" |
Less stroke after final assembly Quote:
ok thanks, will try it. |
I gave up on the stock shocks after running them for 3 days... I ended up going with Traxxas Big Bores. |
Did you put the spacer thats on the outside on the shock shaft in the inside of the shocks |
dude save yourself alot of grief. just go out and buy some better shocks wether its a set of traxxas big bore's or a set of integy hop-ups its worth it to save your sanity. i have tinkered with those crappy shocks and springs for about 1 month before getting rid of them.. The shocks are worth keeping if you are going to use different springs and make the necessary adjustment to make them work, if not get rid of them... just my 2 cents:) |
Thanks guys.. I do have one boneheaded mistake that I made last night and don't know if I should fix it or if it even makes a difference at all. I put the steering on the wrong end, don't ask me how I did it and did'nt notice it till this morning. I was up late putting it together last night. Does it make a difference? by having the transmition facing the other way? |
You can run the transmission either way. Makes no difference really. And personally, I have no problems or issues with the stock shocks. I put the travel limiter inside, and then made new outside limiters. So the shock is both shorter and travel limited, and it works just fine. I also use the stock springs and have no complaints. No preload spacers either, as torque roll is a minimum with the TCS Boomerang upper link mount. I went to a softer spring, and ended up going back to the stock springs. If I run the lightweight wheel set up, the truck is a maybe a little stiff. If I run the heavy wheels, the springs are almost too soft. 8) |
I havnt had a problem with the stock shocks since I put the limiter on the inside and got rid of the O ring. Now the shock caps dont pop off. I think I am going to get some traxxas shocks anyways though. |
Is there a axial rep here? Id like to get the right rear knuckles so I can add rear steer later. I read somewhere here that a dude wrote and got the right ones mailed to him for free?????? |
No problem Quote:
we'll see, got all the electronics working and installed. working on the tires now. I ended up cutting about a 1/4 widthwise out of the foam, sidewalls have nice flex and tread is firm. |
Hi all, I got my ax10 all put together except for the body. I have question about the noise I hear when running the truck? It sounds like a loud gear noise whenever I'm under power. Is that normal, The torque is awsume, even with the stock 7.2volt 6cell battery running the 55t motor. I know I have some tweaking to do but was wondering about the noise? Just wanted to say thanks for all the help and tips... |
Air gab? Quote:
Try to increase that gap with very small steps. If the gap is however too big you may brake the plastic tooths on the spur! NO NO NO"thumbsup" |
thanks rakuda, that was the problem. I loosened the pinion and no more noise. thanks |
