11-24-2007, 11:53 PM | #1 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
| J2-TT/Axial SL
I've been blown away by the Axial axles and tranny I am running on my tuber so far but I am not totally sure a tuber is the best way to go. I wanted to try something out that I know would work well with a bit of a twist. I wanted an superlight (SL) comp rig, hopefully less than 4 lbs but close would be good. I got my second J2-TT from Reign Products, its the new narrow chassis. I wanted to use most of the stuff from the axial kit. Everything has to stay low, no wheel weight will be used but all electronics will be light, low, and placed right. I mounted the links below the Reign Link Plate to keep the links as low and as close to parallel as possible. Upper shock mounting might change for more progressive geometry but I want to try it here first. Specs Axial Axles w/ RCP alloy knuckles, c's, lockouts, and straight axle adapters Axial Tranny Axial Links OG Revolver w/Mamba 25 and Castle BEC Hitec 5995 Servo Axial Beadlocks Losi Tires Spektrum 8s 1500 saddle pack from Holmes Hobbies Here's some starter pics. |
11-25-2007, 12:09 AM | #2 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
whats your wb looks a little bit long.
11-25-2007, 03:46 AM | #3 |
I wanna be Dave Join Date: Sep 2005 Location: *
Z, you are a sick sick man...
11-25-2007, 08:06 AM | #4 |
| 12.5" on the nose. How would I ever build a descent crawler without your comments and brilliant observations I know. Its absolutely terrible. At least this is just a rebuild of my kids and not a whole new crawler. |
11-25-2007, 10:57 AM | #5 |
I got it pretty much finished up. Everything is mounted low and forward. My 8s packs aren't here yet so some 6s packs will work for now. I found out one of the rear shocks has a bent shaft so off to the LHS tomorrow. Also, I couldn't get full steering with the shocks on the outside so they moved in. I love how narrow low this is. Every time I build a Reign chassis they go together so smoothly and easy. Here's the pics |
11-25-2007, 12:17 PM | #6 |
I had a Parma 34 body laying around so I decided to use it. Just a quick and dirty paint job. It fits perfectly, sits super low and kinda has a different look. I found out I definitely need softer springs. The thing that is blowing me away is its stability. It does not want to roll. Well that's it, hopefully some action pics later today. |
11-25-2007, 12:23 PM | #7 |
Quarry Creeper Join Date: Jan 2006 Location: lehi, Ut.
dude I love the slot car track... can I play?....
11-25-2007, 04:10 PM | #8 |
11-25-2007, 08:45 PM | #9 |
11-25-2007, 08:53 PM | #10 |
Super light is totally 2008 man! So is no wheel weights. Because your wheels should be heavy. But you sold the sweetest HEAVY wheels in the world to me! HAHAHAH!!!
11-25-2007, 09:06 PM | #11 |
| Hahahahaha, laugh it up sucka. Wheels might get a little heavier but I want to try it this way first. Its off to the scale tomorrow at the shop.
11-25-2007, 09:13 PM | #12 |
11-25-2007, 09:19 PM | #13 |
11-25-2007, 09:21 PM | #14 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I love me Reign chassis's. They are great. I have two K2-3L's and one J2-TT already. I have been considering getting a second J2-TT to replace my sons AX-10 chassis as well. I agree that low CG and lite weight is the way to go. Nice rig and body. I have the same body sitting collecting dust and it's nice to know it will fit easily. I guess I should paint it and get some use from it. Are those standard Maxx Big Bore shocks (length)? Do you happen to know if a R2D will fit in the J2-TT narrow chassis? Last edited by Nova's Ark; 11-25-2007 at 09:24 PM. Reason: spell check |
11-25-2007, 09:26 PM | #15 | |
The R2D would be really tight if it does fit. The shocks are some traxxas aluminum longs, not big bores though. | |
11-25-2007, 09:37 PM | #16 |
Thanks for the info on the R2D. What is the length of the shocks then? If I do this, I want to have a good idea of what parts are needed so I can get all the parts ordered at once.
11-25-2007, 09:40 PM | #17 |
11-25-2007, 09:44 PM | #18 |
Hey novah's arc, too bad I didn't know you were in the market for another j2, I just pawned mine off for $25.00. I got a great deal, haha I like that shock/spring setup Zach it looks great.. Last edited by fathead; 11-25-2007 at 09:50 PM. |
11-25-2007, 09:49 PM | #19 |
11-25-2007, 09:50 PM | #20 |
what do you mean |
