Thread: New links for my axial
Old 12-04-2007, 05:18 PM   #1
Default New links for my axial
Made some new links for the rear. What do you think?
Rockcrawler is offline   Reply With Quote
Old 12-04-2007, 06:58 PM   #2
Nice work...mine are very simular.
Jonnie Fraz is offline   Reply With Quote
Old 12-05-2007, 07:59 AM   #3
Very nice job Rockcrawler what size tube did you use I was asking because I made my own 70mm upper links out 3/16 solid rod and they turned out pretty good
JUSTGOINGSLOW is offline   Reply With Quote
Old 12-05-2007, 08:04 AM   #4
Thanks guys. I believe its 1/4 . But the best thing is that its stainless. Slides very nice on the rock. When I get everything setup, I am going to make better looking links, just trying to get the length and angels right.
Old 12-10-2007, 08:24 PM   #5
how long are thoes links in inches?
Ben06 is offline   Reply With Quote
Old 12-10-2007, 09:10 PM   #6
125mm or 4.92 inches Center to center.
Old 12-11-2007, 09:02 AM   #7
Nice ! I made some out of 1/4 inch 316 L stainless and love them. I cut mine 4.000 long and bent a 3/4 rad 1.5 inches from 1 end. Makes it only slightly longer than stock. I like the heavy weight links on the bottom,I was running some I made out of black delrin.The flex was good and bad,but the COG differance the S.S. ones make is worth it's weight!
Cave Dave is offline   Reply With Quote
Old 12-11-2007, 09:21 AM   #8
Stainless is the best I have found to use because of the fact that there strong, and slide very well on the rocks.
Dave, do you run comps? I dont think you can with those links because of the WB.
Old 12-11-2007, 09:49 AM   #9
No comps yet... The wheel base came out within a 1/4 in of stock. The nice thing is I was able to get a killer pinion angle. I made a home brew 4 link mount out of 1/4 inch 4140 bar stock for the rear and run much longer than stock links on top. Again the heavy weight in the right spot...centered on the axle.
Old 12-11-2007, 12:19 PM   #10
Did you go ahead and 4 link it?
Old 12-11-2007, 12:24 PM   #11
where do you find stainless to make those?
str8bucs is offline   Reply With Quote
Old 12-11-2007, 12:27 PM   #12
Free from work.
I guess a plumbing shop or something.
Old 12-11-2007, 01:38 PM   #13
Yep,drilled new holes farther forward on the chassis and reused the Axial links with spacers. Works great,almost no torque twist or axle steering.
Old 12-11-2007, 01:45 PM   #14
Go on the internet to McMaster Carr or M.S.C. they both have all sizes and can get them to you overnight if needed. They also are a great source of screws and all-thread. I also get it free from work.....somtimes I order a little extra material for jobs !
Old 12-11-2007, 10:48 PM   #15
BLING!
miller is offline   Reply With Quote
Old 12-12-2007, 11:18 AM   #16
Those look really nice! Did you have to tap (thread) the stainless rods or did they come pre threaded?
ky_18b is offline   Reply With Quote
Old 12-12-2007, 01:08 PM   #17
I used stainless tubing and all thread on mine.
Old 12-12-2007, 01:18 PM   #18
Hay Rockcrawler what is the degree of angle right now and how far up do you have the bend
Old 12-12-2007, 01:30 PM   #19
Not real sure on the angle. I just had 2 spare pieces sitting here so I bent one until it looked right, then just matched the other. I am still working on them so things are going to change. I have already cut 1/4" off of the bent side. Still needs a little more to get them level.
Old 12-12-2007, 02:18 PM   #20
I think i'm going to make the attempt to make my own bent links I have to just get some kind of a angle gauge just to get close but pretty much by eye
