Thread: Rear Dig for sale?
Old 11-17-2007, 12:56 AM   #1
Default Rear Dig for sale?
I want to put rear dig on my scorpion, but I don't want to make one or spend over 100 bucks on the R2 tranny. I have seen many homemade setups that seem to work and was wondering if anyone carries a kit of some kind?
mysharona is offline   Reply With Quote
Old 11-17-2007, 01:10 AM   #2
nope, nobody sells a kit. why not make your own? theyre easy.
dieselfuel is offline   Reply With Quote
Old 11-17-2007, 01:13 AM   #3
oh, you know... laziness
Old 11-17-2007, 01:16 AM   #4
ok then if say I were to make the attempt, anyone think of the strongest way to make such a rig? I like my equipment to be reliable.
Old 11-17-2007, 06:23 AM   #5
just use the good old "search" button. i did earlier and found 3+ different ways to make a dig setup. all of them look pretty strong.
elbo is offline   Reply With Quote
Old 11-17-2007, 06:44 AM   #6
binaryterror's Avatar
I bet if you took the time and effort to consistently make a "home made" dig set up work it'll cost you more than $100 to do it accurately.
Don't be cheap or lazy...
binaryterror is offline   Reply With Quote
Old 11-17-2007, 05:19 PM   #7
TEAM MODERATOR
Reflection's Avatar
Not really accurate info IMHO.
I made the disconnect set up on my 2.2 Hustler for about 5-7 bucks. It's merely a set of maxx shafts cut,trimmed and installed correctly. Then,a cheapie servo would have worked,so about $25-30 for that and your good. I had a 359 sitting here so I used it.
Reflection is offline   Reply With Quote
Old 11-18-2007, 12:34 AM   #8
hey guys I made a dig for my ax10. made a servo/4 link/dig mount was pretty easy. to make the slider on drive line to look good took practice. once you get that down its not hard. Using a dig in a comp. is A+ but I would snap drive lines some times that was no good. so right now not running a dig. as for money not sure but a lot of time to get it right. after that making a dig is easy.IMO
tapped-out is offline   Reply With Quote
Old 11-18-2007, 07:01 AM   #9
If you can get a back copy of RC car action the July 2007 issue has a step by step instructions on how to make a dig setup
quads4_life is offline   Reply With Quote
Old 12-17-2007, 11:42 AM   #10
how do you make the rear dig setup for the ax-10
call me dumb but i can not find the posts on how to do it.
thanks joe
joen007 is offline   Reply With Quote
Old 12-17-2007, 11:48 AM   #11
This is how I did mine and it works flawlesley http://orcrc.com/forum/showthread.php?t=59
drzjohn is offline   Reply With Quote
Old 12-17-2007, 01:07 PM   #12
thank you for the info but now i need to fig out why the pics will not open
Old 12-17-2007, 01:08 PM   #13
thanks joe
Ok, you're dumb
Seriously though, I did a quick search for "rear dig" and within four threads of reading, found two threads on this site with detailed information on how to set-up dig on an AX-10 (or really any rig compatible with Maxx half shafts).
Are you just being lazy?
ecoli is offline   Reply With Quote
