12-06-2007, 03:13 PM | #1 |
Newbie Join Date: Jun 2006 Location: B_town, CO
| The Woodchuck
Well since i don't have any rocks at my place to crawl over, i named my scorpion the woodchuck because it gets to play on the large woodpile I have in back. So here are a couple action shots, and a few body off shots so everyone can see a few of the changes I am trying out, to see if I like it or not running a droop setup. Links moved inside chassis plates 4 Link rear Bent rear links Droop setup with big bores, internal springs, axial shock shafts and relocation brackets 7 cell 2/3A pack on front axle Last edited by dc2drifterx; 12-06-2007 at 03:26 PM. |
01-24-2008, 01:53 AM | #2 |
Wow, almost 400 views without any comments. Is my build that bad? |
01-24-2008, 01:59 AM | #3 |
RCC Addict Join Date: Dec 2007 Location: Calgary
why did you mount your shocks like that? How do you like that servo, does it have enough power?
01-24-2008, 02:02 AM | #4 |
Newbie Join Date: Aug 2006 Location: snowta
I too would like to know what is up with that shock mod? Haven't seen that before.
01-24-2008, 02:12 AM | #5 |
This may be a noob question but, i thought the top links get mounted under the plate and not on top. How does that work for you?
01-24-2008, 03:50 AM | #6 |
Newbie Join Date: Jan 2008 Location: monroeville
any pics of internals of shocks. oil wt ect...
01-24-2008, 05:49 AM | #7 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Actully your better off turning those shock mounts that you made up 45 degrees. The more upright your shocks are the better they perform. |
02-05-2008, 12:31 PM | #8 |
The brackets were made to get the shorter shocks to let the chassis sit where I wanted it. Justgowinslow, thanks for the advice, ill try and make some new brackets up. |
02-05-2008, 12:57 PM | #9 |
Pebble Pounder Join Date: Jan 2008 Location: winston-salem
02-05-2008, 02:32 PM | #10 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
looks good, but I think your shock angle is terrible.What is your Wheel base?? To rise my truck up a little I just drilled new holes in the Chassis.
