01-11-2008, 10:18 PM | #21 |
Oliver Custom Knives Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
Sweet tubers
01-11-2008, 10:21 PM | #22 |
SICK! I've always wanted to try the 3 link/pan hard set up. I need one of these. |
01-11-2008, 11:37 PM | #23 |
Newbie Join Date: Nov 2007 Location: Norcal
Those look awesome, can you tell us the WB ?. |
01-12-2008, 08:50 AM | #24 |
Rock Crawler Join Date: Jan 2004
It is set up to use all stock axial ax-10components so it has the wheel base adjust ability as the ax-10. |
01-14-2008, 10:13 PM | #25 |
Pebble Pounder Join Date: Jan 2006 Location: Fairfield, PA
| shock oil
Slinky sam can you tell me what wieght of shock oil you use for the droop setup?Josh
01-14-2008, 10:52 PM | #26 | |
RCC Addict Join Date: Apr 2004 Location: Santa Clara
Here you go: http://www3.towerhobbies.com/cgi-bin...?&I=LXKKE3&P=7 It still leaks through the shocks, but this oil is about right for the weight of TINY. You may need to get a different weight depending on your vehicle setup. -Sam | |
01-15-2008, 02:15 AM | #27 |
Newbie Join Date: Sep 2004 Location: San Diego area
| One of the coolest lines in crawling. I remember having to do that years ago in an RCAA event. Almost the exact same line you're on. I ended up needing Rear Steer to get it PLUS the left-hand cone. Funny thing is, I remember that place vividly, but cannot remember from WHERE! Love the three link + panhard setups. The definitly have their place on the right vehicle. With a spooled rear axle, they don't perform as good as on an open diff with cutting brakes. In scale, the performance will be similar and the side you want the pumpkin on, directly relates to the rotation of the driveshaft. The rotation of the shaft affects torqueroll, which can be countered by your upper link position as well as a combo of that plus your panhard angle. I've never even looked at R/C crawler driveshaft direction... ...but I'm confident it applies. Last edited by RedBullRockIt; 01-15-2008 at 02:43 AM. |
01-15-2008, 08:21 AM | #28 |
It is actually not a comp line unless they had one there I didn't know about. It is in Penrose It's the exit of independence Before they paved it. |
01-15-2008, 10:06 AM | #29 |
01-15-2008, 10:15 AM | #30 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Yeah we are planning to offer the chassis with both the panhard and a 4 link plate so the customer can determine which set-up they prefer. The panhard definately takes some getting used to.
01-17-2008, 11:12 AM | #31 |
Rock Crawler Join Date: Mar 2006 Location: North Carolina
