12-16-2007, 06:00 PM | #1 |
Newbie Join Date: Jul 2006 Location: Greenville
| Turning Radius
Can any one measure the turning radius of their rig? Are there any 4WS guys out there? What does it turn? Thanks.
12-16-2007, 06:09 PM | #2 |
12-16-2007, 06:24 PM | #3 |
12-16-2007, 06:35 PM | #4 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
On my Scorpion I'm running Axial beadlocks with regular 2.2 Moabs with the foams cut down to about 4 inch diam so they roll under pretty good with a wheelbase of 12 inches. The steering is stock, no after market knuckles or axle shafts I get about 6.5 foot diameter with just the front and if I remember right, it seemed under 3 foot with rear steer. I pulled the rear steering off so I can't measure it at the moment. I'm thinking about putting it back on since I don't have any reason to keep it comp legal. |
12-16-2007, 09:06 PM | #5 |
Rock Stacker Join Date: Mar 2007 Location: yakima
before my truck was comp legal i ran a punk steer and 4ws, it would turn 180' in les then three feet easily, closer to half that, it seemed like it was pivoting.
12-17-2007, 05:34 AM | #6 |
What is punk steer?
12-17-2007, 09:53 AM | #7 | |
Punk steer? I have never heard or seen that term before....I am noew though. 180 feet in less than 3 feet? What? | |
12-17-2007, 10:30 AM | #8 |
Rock Crawler Join Date: Jun 2007 Location: Flint/Mt. Morris
Its like a clod rear steer system I think. And that should be * I guess for degrees. If I remember right its a switching system like with the tq3 you flip the switch between, 4ws, front steering and I think if you have a 3 way switch, independant rear steering.
12-17-2007, 10:12 PM | #9 |
yes that is correct, one hundred and eighty degrees. the punk steer is a little computer that looks like an esc. you run it inline with your reciever and servos. it allows you to have front, four, or crab steer with any three channel remote. do a search and you will find it quick. mine worked great, but its not comp legal so i took it off. im just running a jrxs3 radio. hope that helps.
12-18-2007, 06:09 AM | #10 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
My ax-10 has a turning radius of a SEMI truck Put RCP knuckles etc that helped , but now just got done with dig. Can't wait to see it work (outside) |
12-18-2007, 06:14 AM | #11 |
Rock Stacker Join Date: Oct 2007 Location: I found Dorothy
Here ya go: http://www.clodmodracing.com/ |
12-18-2007, 01:20 PM | #12 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
12-18-2007, 04:04 PM | #13 |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
