12-20-2007, 10:15 PM | #1 |
| Removing the pinion gear E-Clip
I installed the pinion gear on the shaft and then the e-clip. Forgot to check for endplay of the pinion on the shaft and there is too much. I can't get the e-clip off without damaging the pinion, e-clip or both! It is ALOT tighter than any other e-clip that I've ever used on other RC's. Axial didn't even put one extra eclip in the kit! Has anybody successfully removed and reinstalled these clips and how did ya do it? Last edited by Natedog; 12-20-2007 at 11:12 PM. |
12-21-2007, 12:00 AM | #2 | |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
dont know how to help other than suggesting to order another! here is a heavy duty set that looks like it 86's the retaining clip http://www.ckrccrawlers.com/shop/ind...roducts_id=374 its like 30 bux to solve your problem and and its beef | |
12-21-2007, 12:22 AM | #3 |
Quarry Creeper Join Date: Oct 2007 Location: vista - san diego
ya i used the rong pin and i had to take mine off. take a pair of needle nose pliers and put each piont at each of the points on the open end and push, and also i used a regular pair of pliars and i put one side on the open side of the e clip and the other side of the pliers on the pinion and that will unseat it enough to usr a pair of needle nose to get it off and last one take needle nose and put one point into the back of the e clip where they is a space and pull i have succesfully performed all of these but watch out the clip will go flying so have you hand over it when its going to come out
12-21-2007, 12:25 AM | #4 |
Rock Crawler Join Date: Apr 2007 Location: portland
needle nose pliers. You have to try and open the clip by bending the prongs back. Its a small little bugger but it is do-able.
12-21-2007, 12:51 AM | #5 |
Rock Stacker Join Date: Aug 2005 Location: Mesa
You might also try a sharp pick. I have a small pick set just for doing this sort of thing. If you can get the end inside the E portion of the clip, you might be able to pop it off that way.
12-21-2007, 08:41 AM | #6 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
#00 flathead screwdriver. Just stick it under the center ot the clip and cover your eyes, those suckers fly sometimes!
12-21-2007, 09:20 AM | #7 | ||
Was going to buy those but they were out of stock. Quote:
Forgot about my tiny screwdriver set, thanks! Last edited by Natedog; 12-21-2007 at 09:23 AM. | ||
12-21-2007, 07:48 PM | #8 |
Rock Stacker Join Date: Jun 2007 Location: Calgary
Ever hear of snap ring pliers?
12-21-2007, 08:12 PM | #9 |
12-21-2007, 08:24 PM | #10 |
Same shit different pile.
12-22-2007, 12:59 PM | #11 |
