12-22-2007, 01:44 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: UK
| front diff
Is there a front diff that will fit the axial housing to be able to run either open or lsd? Thinking of going scale-ish so will need the turning circle. cheers |
12-22-2007, 01:56 PM | #2 |
The Wheely King diff assembly will prolly fit just fine and the ring and pinion gears are the same size and pitch: http://www3.towerhobbies.com/cgi-bin...?&I=LXPZX9&P=7 This is the Differential Gear Set for the HPI Wheely King, HPIC1082. FEATURES: Metal Construction INCLUDES: One differentail gear set assembled REQUIRES: Installation There is an optional hardened spider gear set to go inside the diff if you want more strength. Last edited by Natedog; 12-22-2007 at 01:58 PM. |
12-22-2007, 02:41 PM | #3 |
Even when doing scale runs it is nicer to have the capability of a fully locked axle. Its a scale truck, are you really worried about taking a reverse? Keep it locked. |
