12-25-2007, 05:56 AM | #1 |
Newbie Join Date: Aug 2006 Location: china
| how can i set the AX10 rear steer kit IN my M11?
how can i set the AX10 rear steer kit in my M11? en..where the rear servo line get in ? same the way as front servo? or in the aux ? thanks:-( |
12-25-2007, 12:03 PM | #2 |
I wanna be Dave Join Date: Dec 2007 Location: Florida
A servo "Y" harness will allow you to plug both servos in to the steering plug on the receiver. That is the basic way but there are other ways if you want selectable independent steering.
12-25-2007, 02:27 PM | #3 |
Rock Crawler Join Date: Mar 2007 Location: Colorado
if the reciever has a 3rd channel, plug it into that one, unfortunately i dont know how to set up an M11 but being a 4 channel radio you should be able to have independant rear steer.... dont know really
12-25-2007, 03:50 PM | #4 |
Quarry Creeper Join Date: May 2007 Location: Seattle
If you've got a 3 channel Rx and you're just trying to set the radio up, it's pretty simple. 1) Find the C-MIX tab on Page 2 (F2). There are two sub menus, C-MIX1 and C-MIX2. In C-MIX1 you need to have the Master be ST1. In C-MIX2 you need the Slave to be AUX. At the bottom of the C-MIX2 tab is another option for changing the mixing, you want it to be set to INH to make it mix the channels opposite of one another. If it is set to ACT the mixing will not work. Unsure what the meaning of any of that is really, I just messed with it until I got it to work. That's how I got mine to work. I just turn the C-MIX from ACT to INH when I want my rear end to steer. |
