Thread: 1BadJeepBruiser's Ax10 Xtrail Bronco RTR with Videos
Old 01-22-2008, 09:34 AM   #101
The bumper looks awesome Mike, This might be a stupid question, but what exactly is the Jig that your using to hold the peices in place when you braze? This has been the one thing holding me back from trying it out, I havent been sure what to get to hold the parts together. Keep up the good work, your giving me more and more ideas for my bronco!
**edit** nevermind, I used the SEARCH BUTTON and found out exactly what you meant by third hand, Thanks for the idea!
Larson627 is offline   Reply With Quote
Old 01-22-2008, 10:49 AM   #102
Im Brandon
Brandon's Avatar
Originally Posted by AeroSynch View Post
Did you get the hardware kit?
Thanks..lol
No hardware kit. I used my own shocks so the internal springs in the kit would have been useless. And I have so many random screws laying around I can usually find something that will work
Brandon is offline   Reply With Quote
Old 01-22-2008, 11:22 AM   #103
lol, kk thanks. Now I got to go order the chassis..
AeroSynch is offline   Reply With Quote
Old 01-22-2008, 11:24 AM   #104
Im Brandon
Brandon's Avatar
No problem, if you have any questions about building it with the tlt axles feel free to ask in my scout thread. Dont want to pollute Mikes Bronco thread
Old 01-22-2008, 08:39 PM   #105
Sinking with the ship
1BadJeepBruiser's Avatar
Started on some door panels tonight...
I then went on to the Wild Horse site to see how the panels look and saw these http://www.wildhorses4x4.com/product...et/Door_Panels
So I added that to mine
The I made the door panel based off the this
http://www.wildhorses4x4.com/product...at/Door_Panels
I think I may have angled them a lil bit to much but thats alright
lastly for the night, the window cranks
More to come
Old 01-22-2008, 09:44 PM   #106
Your Bronco is looking killer...Awesome detail!
here's a couple shots of the 2.2 scaler body I am going to use for my Wifes build. Wont be as nice as yours, but it will do.
bmuzz1 is offline   Reply With Quote
Old 01-24-2008, 08:38 AM   #107
looking great as usual!
XSRCdesign is offline   Reply With Quote
Old 01-24-2008, 08:46 AM   #108
Oh no not door panels. Bmuzz that body is nice, dont sell yourself short before you even begin.
cembom is offline   Reply With Quote
Old 01-26-2008, 03:24 PM   #109
Well I lost one of my window cranks I made so I was irritated and didnt feel like working on the door panels then, so instead, I decided to finish off the front bumper
1st order of business was to take apart my Juggsterr winch, and get it painted up
after some paint
The using some fishing line from walmart, I started to work on getting the winch barrel wrapped up with some line.
Cool thing about this stuff is, that its strong and can be used for line if I decided to make the winch functional down the road.
I put a small dab of tire CA and started wrapping it
After I got a descent amount on, I hit with some testors aluminum silver paint, its gives it the perfect look
After that I was able to put it all back together
I used a hook from garden trucking's website (http://www.gardentrucking.com/produc...esort=1&max=10)
I mounted my control box by making a small "L" shape bracket off of the end of the winch
I also drilled a small hole and put a small piece of steel rod in as a engage/disengage lever
All said and done... it looks badass
Old 01-26-2008, 03:42 PM   #110
Looks SWEET Mike- Great job on the detail work..!!!! I gotta get me one of those winches.., those look SO cool..!!!
51WillysJeep is offline   Reply With Quote
Old 01-27-2008, 09:37 AM   #111
Mike, you spelled budget wrong
in this instance it's I N T R I C A T E
william g is offline   Reply With Quote
Old 01-27-2008, 06:29 PM   #112
Thats amazing! I think I will have to start a scaler build..... This is such a cool looking truck, I cant get over it!
How much do you have into this thing minus the elec's?
Jo Mama is offline   Reply With Quote
Old 02-12-2008, 07:47 PM   #113
Well its been a while since I have been able to work on this, I went from having NO job to 2 jobs working 56+ hours a week... so time has been limited.
I wanted to get going on this interior, so I mounted up some TLT servo mount post to serve as brackets
I then cut some pieces of .060 thick styrene and bolted it on to the servo mounts, sat the seats on them for a quick mock up
Then got some paint on them
While the paint dried, I detailed my door panels that I made
here is a peak through the window, unfortunately you dont see my diamond plate kicker panels but they are there
I also finally got a chance to install my new goodies from The Crawler Store. I got some RC4wd straight axles adapters and shocks
I mounted the shocks in board this time around
Also got some Hot Racing Cs and Knuckles, really nice fit and finish on these. I love how they went back and milled down the sharp edges after the anodizing. The also come with cool covers to hid the bolts but they were green and I didnt feel like stripping them so I left them off for now
I also figured out the issue behind the rc4wd shocks "sticking" as some may have experienced. I took the shocks apart and actually found that there are 2 different size O-rings and one is to small (in my opinion) and appears to be causing the sticking...
my solution is the following
Remove shock ball end and shock body lower cap. Also remove the top cap and spring
Remove the 1st O-ring and youll see there is a plastic bushing inside the shock body
Youll then reveal the 2nd O-ring, this is the one that seems to be to small and is causing to tight of a fit which leads to the shock piston 'sticking' occasionally
In this pic, you can clearly see the size difference
Now, take the larger O-ring, and put that back in the shock body 1st, followed by the spacer and LEAVE OUT the 2nd O-ring that has a smaller ID.
Once back together youll notice the shock returns and moves so much more freely then before. I cant guarantee it will hold oil, but Im not concerned with that anyways since I am using the internal spring
Lastly, I used a traxxas rod end on the shocks. The stock ones dont seem to have enough material milled away around the ball carrier end itself and the ball doesnt protrude far enough out then to allow the shock end to rotate and twist around as necessary. With the Traxxas rod ends it has a lot better movement.
Well thats it for now, more to come
Old 02-12-2008, 08:51 PM   #114
What is the difference between the grease in the kit and heavy white lithium grease?
fidencio74 is offline   Reply With Quote
Old 02-13-2008, 11:35 AM   #115
What length of shocks did you get?
gobucks is offline   Reply With Quote
Old 02-13-2008, 01:22 PM   #116
PapaGriz Yo
Grizzly4x4's Avatar
Originally Posted by Unimoger View Post
In this pic, if the body clip was not there, I would have looked 3 times, the realizm is amazing Mike, you are a true scale craftsman
Mike, I'm going to have to ask you to stop posting pics of 1:1 Broncs in this section. Take it to chit chat.
OMFG......you rock man.
Grizzly4x4 is offline   Reply With Quote
Old 02-13-2008, 01:40 PM   #117
~THE SCALE SHOP~
what camera are you using, even the indoor shots are quite crisp....
STANG KILLA SS is offline   Reply With Quote
Old 02-13-2008, 03:12 PM   #118
nice looking rig mike, can't wait to see it in person. you also have a PM mike.
HITMAN is offline   Reply With Quote
Old 02-13-2008, 03:14 PM   #119
Canon PowerShot S3 IS
EXIF reader for the win...
Cosmo-Graphics is offline   Reply With Quote
Old 02-14-2008, 04:04 PM   #120
Holds to the gears better in my opinion, I have always used this stuff and I have never stripped a ring in pinion in my TLTs or Bruisers.
90mm
Thanks Chris, but it still doesnt compete with Guido
cosmo is correct, its a cannon power shot IS S3, great camera for the price
Thanks Joe, Ill reply to your pm now.
-Mike
