Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: The Wombat
Old 01-21-2008, 12:26 AM   #21
The preload on the LH spring was an attempt to reduce torque twist. The pics are from a testing run, and much as changes with the shocks. I was having binding as the suspension cycled, and had to play with shock and link placement to get it smoothed out. I spent a couple of hours today trying different setups for the rear suspension. Tomorrow I will work on getting the front set up refined.
dystance is offline   Reply With Quote
Old 01-21-2008, 04:55 PM   #22
my rigs never really done, but I will call this one done, for the moment.
pictures best explain the set up:
ride height:
full droop:
front setup:
rear setup:
Old 01-21-2008, 04:59 PM   #23
test run in t he snow.
I have a small testing area in the front yard. Got out testing with Skippy today and an impressed with the performance of the Wombat. Seems stable and predictable. I will continue to experiment with the setup, but it seems to be very agile.
Old 01-21-2008, 05:10 PM   #24
Lookin good man, I think I saw this rig in Hobbytown the other day maybe last week sometime. I think skippy had it, i've only seen him once at the horsetooth comp but I think it was him. You gonna compete in the winter series at all?
Roadbiker3 is offline   Reply With Quote
Old 01-21-2008, 05:33 PM   #25
Roadbiker3 - you may have seen him there with it, I think I was there to. I am planning on getting to as many comps as life allows. Getting my new career off the ground so time is tight. I am hoping we set another date for a comp up here at horsetooth reservoir this winter. I am bummed I could not make the Palmer Park comp, always great courses.
Old 01-21-2008, 09:08 PM   #26
I really wanted to make it there as well but the time just wasn't right, kids were sick wife was tired. Same ol stuff plus a 2 + hr. drive doesn't help either. So horsetooth needs to be a comp spot soon, can't wait.
Old 01-27-2008, 06:12 PM   #27
got out for the first real test. Overall I am impressed. Just added a suck wench to the front but I have not used it much. Wheelspeed is reasonable and runtime is about 30-40 minutes the way I drive.
I need to finetune the shock setup to free up some more articulaton. Other than that I am happy with i so far. Seems to have good side hill, good climbing ability, and stable.
Pictures
using suck wench to pull front end down.
needs a little more flex
Old 01-27-2008, 06:20 PM   #28
666
MODERHATER™
666's Avatar
Looks hot man!! You and Skippy did a real good job on this one!
How do you like the Proline beadlocks? What are you doing for foam in the front, looks a little soft.....
Keep an eye on those thin tin strips on your batteries. I have been seeing alot of them melting, there should be battery bars in there for optimal performance!
Oh, and I forgot how do you like brushless?
666 is offline   Reply With Quote
Old 01-27-2008, 06:38 PM   #29
The prolines seem great. I mounted them up and have had no issues. Still seem to have a weakness in the hardware being tiny and will likely to have to be tapped with larger bolts after a few tire changes.
The foams are memory foam from a pillow I had. They seem a bit stiffer inthe cold, so maybe I make them my winter foams. It is soft, but seems to sidewall OK, not flopping over too much.
Thanks for the tip on the battery bars, I will look into that.
The brushless seems to do well. My rig is light and seems smooth and has plenty of power, and wheelspeed.
Did you notice a set of Skippy's custom skid plates? They are not pretty but they really help prevent hangups. I may stick with them.
Old 01-27-2008, 06:55 PM   #30
666
MODERHATER™
666's Avatar
No I did not notice the Skippy sleds!
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
