| | #1 |
| Pebble Pounder Join Date: Oct 2006 Location: Mt. Enterprise
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Dec 2007 Location: OP KS
| | #3 |
| | #4 |
| yes it is a problem but i cant seem to figure out how to fix it besides having smaller shocks. |
| | #5 |
| Thanks for the shock suggestion |
| | #6 |
| Quarry Creeper Join Date: Sep 2007 Location: Kelowna BC Canada
| I run team losi xxx-nt ad2 rear shocks all the way around they they work really good. |
| | #7 |
| Rock Stacker Join Date: Aug 2007 Location: Prospect park
| Buy the TCS trail chassis kit and set the shocks up as droop it lowers everything flat. |
| | #8 |
| i did buy the parts kit as well....im still trying to figure out the hole droop process and the way it should be properly mounted. |
| | #9 |
| | #10 |
| Yeh im going to do my shocks like that tonight....im just having a problem now with my stupid front axle wont move when i pull the throttle so i tore the axle apart and i noticed it seemed like on of the bearings right outside the diff was froze up so i unfroze it put it all back together and when i turned the driveshaft the axle turned as well so i was like great! its fixed....wrong....i completely installed it back on the truck and its doing the same darn thing again only the rear wheels turn grrrrrr so now i gotta take it back apart and figure out why the front end isnt working right... |
| | #11 |
| Rock Crawler Join Date: May 2007 Location: lacey
| does the driveshaft to the front axle rotate? if so, you probably need to tighten the setscrew on the shaft to the axle. I had that happen to me out on the rocks, you really need to crank down on the setscrews on the front shaft. they like to loosen up on ya. |
| | #12 |
| yeh set screw came lose i felt so stupid about an hour after i posted that lol i cant believe that was all it was lol |
| Thread Tools | |
| Display Modes | |
