07-28-2012, 10:25 PM | #21 |
| Re: whos got the suicide switch steering?? |
07-29-2012, 07:39 AM | #22 |
RCC Addict Join Date: Feb 2011 Location: York
07-29-2012, 08:54 AM | #23 |
07-30-2012, 05:53 AM | #24 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
pretty simple to make so i did.. i see what you mean.. seems to steer more one way then the other.... going back to stock.. want to upgrade it soon.. its real weak
07-30-2012, 04:25 PM | #25 |
Newbie Join Date: Mar 2012 Location: Brunswick, Maine
I'm not trying to convince anyone one way or the other, the way I set up my truck works for me and the places I like to play. If something else works better for you then more power to you, enjoy it The best thing about this whole site is seeing all the different ways folks build rigs. I'm running a 400plus inch/ounce servo, a JR DS8711, plus a custom made (see wicked bent) servo arm. I was able to adjust my end points to arrive at lock to lock steering, I do have lots of grief with my still stock dogbone axles binding up, but CVDs are on order and I hope that will solve that.http:// Last edited by Countryhandyman; 07-30-2012 at 06:14 PM. |
07-30-2012, 09:18 PM | #26 | |
| Re: whos got the suicide switch steering?? Quote:
Terrible setup. | |
07-30-2012, 10:18 PM | #27 |
| Re: whos got the suicide switch steering?? I'm not trying to throw more fuel on the fire, but I have also found this setup to be inferior to a tie rod/drag link setup. There was a thread not long ago in the AX-10 section about this. I was willing to give this setup another go because of all the positive comments, but time commitments forced me to go with what I had already tested...This setup just did not work for me compared to a Tie-rod/drag link setup.
07-31-2012, 08:49 AM | #28 |
| Re: whos got the suicide switch steering?? Yep, exactly. Having things (servo horn and knuckles) moving in arcs that are perpendicular (actually, not parallel) to one another is what causes the problems with this type of setup...
07-31-2012, 10:11 AM | #29 |
With things moving around in different arcs like that, I felt it made the front wheels feel very "disconnected" from each other. Hard to explain but it made the steering feel unpredictable to me.
08-01-2012, 07:47 AM | #30 | |
Rock Stacker Join Date: Mar 2012 Location: Carson City
I bought the kit. Came with everything. Bought vanquish c hubs and knuckles. I bought the ax30780 axles and I have the same steering as their house rig. Zero binding issues. I love it. Works awesome. No complaints at all. One guy above said this kind of steering is useless and has nothing but problems. What problems were you having. You must have installed it backwards or wrong. Because my buddies and myself have run this setup on our rigs for over 8 months and not a single issue. | |
08-01-2012, 09:12 AM | #31 |
| Re: whos got the suicide switch steering?? I dont know who you are referring to, but they were probably not talking about any mechanical failure issues with this steering setup...mostly just the problems that it introduces into the steering cycle.
08-01-2012, 09:26 AM | #32 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Sure, this steering setup will turn your front wheels, but it is not a very efficient design. This type of setup will only work well if the servo is mounted vertically, with the horn not only parallel to the knuckles, it also needs match the throw of the knuckles too, (the distance from the kingpin to where the rod end is mounted should be the same as the servo's splined output to the rodend mounting point on the horn) AND be mounted to match any clocking angle the knuckles are set at. The servo horn would also need to be centered between the knuckles. The more the angles of the steering rods change in relation to the servo and knuckle throw, the less efficient the steering becomes. If you look at this gentleman's build, he has the right idea for good steering for these axles: BullFrogRC's 2.2S Hybrid Last edited by gunnar; 08-01-2012 at 09:39 AM. |
08-14-2012, 07:03 AM | #33 |
thanks for the link.. i like his steering way more..
08-14-2012, 09:02 AM | #34 |
Rock Stacker Join Date: Mar 2012 Location: Vancouver
i guess if harley says it sucks then it must be true.... HA!
08-26-2012, 10:40 PM | #35 |
Rock Stacker Join Date: Apr 2012 Location: eastern gorge
i love my setup.. works even better with aluminum knuckles and c-hubs. good thrust.. upgraded the servo too and the arm when i did it.
whos got the suicide switch steering?? - Similar Threads | ||||
Wraith suicide steering | Spence700 | Axial Wraith | 10 | 06-03-2012 12:29 AM |
suicide switch | ezee | Axial Wraith | 4 | 02-14-2012 04:34 PM |
Suicide Switch Steering | ScaleFreak93 | Axial Wraith | 26 | 10-08-2011 09:45 PM |
suicide mission... | nosyajg | HPI Wheely King | 1 | 09-11-2011 11:55 PM |
suicide sally | theshimonator | Chit Chat | 5 | 08-04-2007 09:11 AM |
