10-22-2012, 07:17 PM | #1 |
Rock Crawler Join Date: Jul 2012 Location: In a van down by the river
| crunching noise when turning???
Hey y'all, Under heavy steering, to the left, I hear this hideous crunching noise. I've attempted to isolate the sound and it seems to be originating from the axle shaft universals. Is this a common issue with a very high torque servo (7950). I'm still running the stock universals, I'm just wondering if I should upgrade to the VP's... I've done a bunch of mods to the Ridgecrest - Beef tubes, HD gears, VP CHubs & knuckes, etc... Any thoughts on this would be appreciated! Thanks, Todd |
10-22-2012, 08:57 PM | #2 |
Quarry Creeper Join Date: May 2012 Location: Houston
| Re: crunching noise when turning???
I have a lot of the same mods, lots of VP on the axels and stock universals. Could be you locker spinning inside the diff, could the the uni, I had a similar issue with the right but it turned out to be a tire just rubbing the shock spring. Check your EPA on your radio too, you could be turning the universal farther than its supposed to go, causing it to bind.
10-23-2012, 05:39 AM | #3 |
Rock Stacker Join Date: Jul 2012 Location: Tn
Ditto I was gonna say same as gravelduster to check end point adjustments(I had one making noise like that and that what it was)
10-25-2012, 12:25 PM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: BC, Canada
A squirt of lube on the universals....... |
10-27-2012, 07:35 AM | #5 |
Thanks all... It was the EPA - fixed!!! Now, back to crawling... Cheers, Todd |
crunching noise when turning??? - Similar Threads | ||||
What Is This Noise??? | rockcrawler150 | Losi Mini-Rock Crawler | 7 | 07-30-2011 05:36 PM |
540 Noise | huffman81 | Redcat Crawlers | 5 | 04-04-2011 05:55 PM |
noise | 93 FORD BRONCO | Axial SCX-10 | 16 | 01-19-2010 01:57 PM |
Turning ? | scoobysnacks | HPI Wheely King | 21 | 09-09-2008 07:01 PM |
turning | Herzog-racing | Tamiya Txt-1 and Juggernaut | 5 | 06-11-2005 10:20 PM |
